Can't reprogram MDT AKK-1616.02
    Hi, i have an MDT AKK-1616.02 actuator. Programmed this one about a year ago and worked flawlessly. No i want to reprogram it using ETS 5.6.4 but when i push the programming button on the device nothing happens. The red led goes on, but ETS does not start the download. The actuator still works perfectly with the old configuration. I can see this in the bus monitor. It looks as if the device never goes into programming mode. I already complete powered off the bus. Removed and recreated the device completely in ETS. No solution. I programmed an AKK-1616.03 with success. Broken AKK-1616.02?
  • duncan
    • 320
    some versions of loxconfig dont work with some versions of ETS as a gateway for programming purposes - eg the current beta
    the current release version seems to work with 5.5.4
    try an older version of ETS, or possibly reflash the miniserver to an older version, or a separate knx programming interface instead of using the miniserver
      Forgot to mention. I use an MDT knx ip/usb gateway.
      • duncan
        • 320
        ok - so can you reprogram any other devices?
          Yes, i programmed and reprogrammed several different devices. I've contacted MDT support, and they suggested to send the device back for repair.
          • duncan
            • 320
            its obviously not ETS or loxone then, so sounds like returning it is the only solution
            • Nobbi75
              • 1264
              I had a similar problem...
              Are you 100% sure that you use the correct driver version (.02) for this device. I would delete it from the ETS and reinstall it from the MDT archive download site. Do not use the driver for the .03....
              Gesendet von iPad mit Tapatalk Pro
