I have made progress! Thank to all who commented. The comment regarding the voltage of the KNX power supply was enormously helpful. I never imagined that a power supply sold in the United States would be 220v. Instead of searching for a new power supply, I asked my electrician to wire it for 220v.
Next I had to work on proper wiring. I have six panels in different locations in the house. I used a toner to locate the ethernet cables and corrected any wiring issues. Once I saw 30v, I knew that I was successful with fixing the wiring.
I have been able to get most of my switches recognized and addressed by ETS5. It was a wonderful feeling watching the green bar show progress and completion of the commissioning.
I am now trying to integrate ETS5 and Loxone config and I am a bit confused. I have set up the line addresses for my switches. They have 4 areas that can be touched (plus multi-touch etc.). For example, the master bath is 1.1.6. I have a top level section (6) for the master bath, (0) for on/off in the middle and then 0, 1, 2 and 3 for the four sections for the last addresses. Top Left (6/0/0), Top Right (6/0/1), Bottom Left (6/0/2) and Bottom Right (6/0/3).
Is that all I need for Loxone? Loxone Config sees the line addresses for each switch. I am still uncertain how to program the group addresses into Config. I am also uncertain what other addresses I need to establish in ETS5 for the thermostat which is in the switch. It would seem that ETS5 would just set up the switch as a dumb terminal and Loxone would send it the 0s and 1s but I just don't know. The Loxone documentation is very helpful.
Thank you in advance for your assistance.
David
P.S. In case you are wondering, I am an American that hates Trump.
