sunrise minus 1 hour
    Hello all.
    I am trying to introduce a variable time to switch on the lights in my courtyard in the morning before sunrise. The idea is that the lights will go on about 1 hour before sunrise, and after about 1 hour be turned off via the KNX daylight sensor. I have arranged the Loxone time sunrise, combined it with an Loxone ADD module, and want this to trigger or send telegram via an EIB-actuator to the correct GA in my KNX bus. But I am not sure how to handle the on-off dimension. I ONLY want the sunrise -1hour to turn the light on, not off. How can that be accomplished? I have seen some places that one uses the GA like 1/2/3:1 or similar. Can someone try to explain the best practice here?
  • hme0354
    • 06.07.2019
    • 970
    you can use the minutes until sunrise minus 60. you can compare that with zero. if this happens it is 1 hour before sunrise
      Thank you. I will try your suggestion...
      What about the off-on? I am thinking like to use sunrise minus 1 hour to turn the light on, and sunrise ,minus 4 hours to turn it off. I guess that the off/on is on the actuator side and linked to the KNX GA address.
      • hme0354
        hme0354 kommentierte
        almost the same and combindes with an rs flipflop
    • Sammy
      • 23.08.2018
      • 413
      Hello,
      I think you can use the "switch":
      Find out more about how the Switch Function block works within Loxone Config.
      There you can use the output Qon or Qoff to trigger only the rising or falling edge.
      Best regards,
      Michael
        Thank you both. As output is linked to a KNX actuator, I guess that I have to use a KNX switch module, to get the correct formatted telegrams to trigger the KNX actuator. And the EIB switch does not have a Qon or Qoff. I have used Live view with manual intervention to make some corrections. However, I won't see the results until tomorrow. I enclose a screenshot.
        perhaps it is all a little confusing. In the screenshot there is 3 arrangements: above: turn lights on in the courtyard in the morning, sunrise minus 90 minutes. Middle: deactivate courtyard movement sensor in treppenlicht mode 1 min before the courtyard lights are switched on. Below: the same as the middle with another movement sensor.
        The issue for me here is to get the EIB switch to work correctly. In terms of sending the correct formatted telegram (datapoint 1), to send ON for the light and OFF to deactivate movement sensors.
        Please let me hear your comments.
        Kind regards
        One (1) telegram only Klicke auf die Grafik für eine vergrößerte Ansicht
Name: Skjermbilde 2020-12-30 122004.jpg
Ansichten: 613
Größe: 64,4 KB
        • Sammy
          • 23.08.2018
          • 413
          In my opinion, you need only one "switch" between the first equal and the EIB Taster and connect Qon with 'T' from the EIB.
          Best regards,
          Michael
            Hello Michael. I am not sure if I understand you correctly. Do you suggest to introduce a regular loxone "switch" module between the "equal" and the EIB switch? When you say "EIB Taster" is that the EIB actuator or is it the EIB switch? Please clarify.
            Kind regards
            Svein
            • Sammy
              • 23.08.2018
              • 413
              Hallo Svein,
              My idea:
              Equal -> loxone "switch" -> EIB Switch
              Best regards,
              Michael
                OK. I will let my present setup work for the next 24 hours, and see how it works. Then I will try what you suggest. It has also been suggested to use RS flipflop.
                Kind regards
                Svein
                  Hello again. Well something happened. The lights went OFF in the evening, not ON in the morning. So something is wrong.
                  I have now re-arranged the modules according to what I think you thought would work. So again, we have 24 hours to see what happens. The world of smart housing is full of surprises.
                  Kind regards
                  Svein Klicke auf die Grafik für eine vergrößerte Ansicht
Name: Skjermbilde 2020-12-31 152942.jpg
Ansichten: 498
Größe: 87,9 KB
                  • hme0354
                    • 06.07.2019
                    • 970
                    the 2nd and 3rd switch will not switch to ON, because you only reset them.
                      OK. I would like them to switch OFF 91 and 92 minutes before sunrise. What do you suggest? Is it possible for you to indicate the correct connections? Use the O?
                      • hme0354
                        • 06.07.2019
                        • 970
                        don't know exactly because i don't have eib
                          • 11237
                          What does the 2nd and 3rd EIB switch group address require to receive?
                          As all your EIB Switches use the Tr input, the group address will toggle, and as no Status input is connected, Loxone won't know what is currently set on the Actuator. Therefore, Loxone may send "1" but the actuator already is "1" .
                          If you don't need to have a switch visu in the Loxone App, you don't need the EIB Switch at all. The KNX output will send 0 and 1 if directly connected to any logic.
                          If you require the UI, make sure always to use O and R on the EIB Switch block to directly send 0 or 1, and not the Tr that flip-flops the output.
                            Hello Christian. I have been doing some trials and failings. And ended up with the solution you indicated. As you can see from one of may earlier messages, I had the EIB correctly connected. As I am testing now, I have eliminated the 2 lower setups, as the watchdogs have been going on and off in an uncontrolled manner and made the results a bit confusing. I hope that during the next 2-3 days I will have the sunrise minus 90 min working correctly, and when that is in place I will try to make the movements sensors also work correctly. Thank you for your advice.
