I am looking into the possibility of integrating KNX and Loxone in a smart project. If I use both systems, is there a way to ensure they work together without compatibility issues?
Is there a need to use any adapters or protocols?
Thanks for your help!
Zuletzt geändert von JohnSteele; 20.01.2025, 09:00.
well, you need a Miniserver and a KNX extension. Further, a gateway (IP or USB) in order to progam the KNX devices. If you have a Gen1 Miniserver (or a Gira X1) you can use this as a gateway.
In a mixed environment I'd recommend to do only the addressing in ETS (inkluding all group adresses you'd like to work with in the Loxone Config) and the whole logic (and visualization) on the Miniserver.
If you haven't bought any KNX devices yet, I'd recommend to go all-in on Loxone. They are here to stay. I'm fine with other thoughts 😊
