Virtual Input Text
    Virtual Input Text
    Hi, why isn't possible to display text from a virtual input? For example I want to display content_type: "audio/mpeg" but I get 0 instead of audio/mpeg. Any help on how to display it would be great. The text is coming from an API call.
    • 11238
    Getting text is only possible if you push it via HTTP Rest interface from your connected device to the Miniserver.
    The HTTP Input can only read values.
    By using \1 in the recognition you can get the ascii code of one single letter. This is useful to recognize TRUE or FALSE (ascii of T or ascii of F), and process the ascii value in a status block.
    PS: To answer the question about "why": Because Loxone didn't implement this.
      Thank you Christian for the reply. Can you point me in the right direction with a link to the HTTP rest interface --> Miniserver setup?
    • 11238
    This is where to start:
    Find out more how you control and configuration of a Loxone system is possible through simple HTTP commands.
    If you create a virtual text input, you can send a call to this VTI via http.
    You can try this in the web browser first.
      Christian, I've succeeded with Postman, thank you very much.
        Hi all,
        i want to do something as well if my pump gives a result of true or false.
        in the command recognition of loxberry i get a different value result as in the miniserver:
        i've attached some screenshots
Name: Screenshot 2020-09-23 at 21.12.28.png
Ansichten: 760
Größe: 217,7 KB
Name: Screenshot 2020-09-23 at 21.12.51.png
Ansichten: 712
Größe: 3,0 KB
Name: Screenshot 2020-09-23 at 21.12.59.png
Ansichten: 720
Größe: 6,1 KB
        Thanks for helping me out here!
        Jimmy
          • 11238
          \2, \3 and \4 is a known issue of the plugin (see wiki).
          Simply use
          "L_pump":"\1
          Zuletzt geändert von Christian Fenzl; 24.09.2020, 08:39.
            Thanks Christian I will try this !
              Hi All,
              I've tried the above but the result stays the same...
              if my L_pump is true the value is 34 (also in loxone) .... if my L_pump is false the value is also 34 (also in loxone)
Name: Screenshot 2020-09-25 at 09.26.52.png
Ansichten: 747
Größe: 221,4 KB
Name: Screenshot 2020-09-25 at 09.29.34.png
Ansichten: 706
Größe: 5,8 KB
              I now understand why it stays the same... ASCII 34 has value "
Name: Screenshot 2020-09-25 at 09.39.22.png
Ansichten: 887
Größe: 29,7 KB
              How can I get the command to move 1 character further so that it detects the letter t or f (true or false)
              thanks in advance!
              Jimmy
                • 11238
                Double-Check the syntax in my post!
                  facepalm! let me copy paste and try again...thanks Christian!!
                    Thanks again Christian, this works now !! I have 2 different values now , 116 when true , 102 when false... much appreciated !!
