Xiaomi switch - MQTT - how to set up in Loxone Config?
    Hello
    I'm looking for help to setup Loxone config for my Xiaomi zigbee switch and Cube
    The Zigbee2MQTT and MQTT Gateway works has expected and I'm getting MQTT messages from/to zigbee devices.
    I hit a roadblock on how to set up the Virtual input for Xiaomi switches. I'm converting the single, double messages converted to boolean. When I make a single click, the virtual input in the miniserver switches to "On" and stays on. I expect an impulse and not a permanent "on".
    The VI is connected to a Push Switch block.
    How do I get the VI to turn back to "off / 0" shortly after the MQTT "ON / 1" message turn the VI to ON?
    thanks a lot!
    0
    Xiaomi switch
    0%
    0
    MQTT
    0%
    0
  • Clubsport
    • 11.01.2018
    • 602
    In the MQTT Gateway, you have to set the checkmark for „Reset after Send“ …
      apologies for not getting back earlier... my mqtt gateway/zigbee2mqtt set up got corrupted following a power outage and had to rebuild the whole thing.
      thanks for the tip, it works flawlessly now!
