HowTo: Per NFC Tags mit iOS Loxone fernbedienen
  • realschmide
    • 26.09.2018
    • 53
    ich habe im Forum dazu einen HowTo Artikel geschrieben.
    Hier ist der Link dazu: https://www.loxwiki.eu/pages/viewpag...ageId=60556563
    Viel Spaß damit.
    kannst Du mir verraten, wo ich die Curl-Anweisung genau unterbringe? Ich bin da nicht so ganz fit. Danke vorab.
    • realschmide
      realschmide kommentierte
      In dem Script open_frontdoor.sh.
  • Giovani
    • 18.01.2016
    • 34
    Hello,
    Sorry to respond in German forum in English.
    I did this (NFC to Loxone) automation in another way (without need of RPi)
    Within Loxone app (which supports triggering particular commands or opening particular app position) by QR codes I created QR code for action I would like to trigger (eg opening frontdoor). When QR code is created I scan it with QR code scanner to get QR code content (content is something like loxonecmd://ms?mac=xxxxxxxxxx&cmd=jdev%2Fsps%2Fio%2F0e1554bf-0151-291b-ffff112233445566%2F1%2Fon&cmd2=jdev%2Fsps%2Fio%2F0 e1554bf-0151-291b-ffff112233445566%2F1%2Foff).
    Then I open iOS Shortcuts app.
    Select Automation->Add (+) -> Create Personal Automation -> Settings -> NFC
    Then scan your NFC tag and add action which shall be triggered when NFC tag is detected.
    Action I use is Web -> Open URL where (as URL) I paste content which was read out of QR code produced by Loxone app.
    (This works only on latest iPhones (X and later) which has NFC always on and where NFC is option in Shortcuts app).
    see also https://www.loxone.com/enen/kb/qr-codes/
    Hope someone find this useful...
    • realschmide
      • 26.09.2018
      • 53
      Certainly a good solution as well. The only pitfall in my setup is, that it would need a WiFi or vpn connection to work. WiFi is sometimes not connected and vpn takes way to long to connect. For cases where these problems cannot occur (stable or already connected WiFi) your solution is definitely better.
      • Joachim
        • 13.07.2023
        • 5
        Bin hier drauf gestoßen, da die smart Tags keine iOS Unterstützung haben (warum eigentlich nicht !?).
        Der verlinkte Beitrag vom Ersteller ist nicht mehr verfügbar oder wurde verschoben.
        Jedoch funktioniert die Lösung von Giovani super
        Thx.
        Joachim
        • dasquiddi
          dasquiddi kommentierte
          Link funktioniert nicht mehr direkt, der Artikel kann aber auf der Seite mittels Suche einfach gefunden werden.
