Ich bräuchte eure hilfe ich möchte über node-red denn Lade zustand meines Teslas auslesen.
der Zugriff auf mein Tesla Konto steht einmal.
Ich bekomme auch daten.
battery_heater_on: false battery_level: 89 battery_range: 276.57 charge_amps: 16 charge_current_request: 16 charge_current_request_max: 16 charge_enable_request: true charge_energy_added: 26.29 charge_limit_soc: 89 charge_limit_soc_max: 100 charge_limit_soc_min: 50 charge_limit_soc_std: 90 charge_miles_added_ideal: 110 charge_miles_added_rated: 110 charge_port_cold_weather_mode: false charge_port_door_open: true charge_port_latch: "Engaged" charge_rate: 0 charge_to_max_range: false charger_actual_current: 0 charger_phases: 2 charger_pilot_current: 16 charger_power: 0 charger_voltage: 2 charging_state: "Complete" conn_charge_cable: "IEC" est_battery_range: 171.29 fast_charger_brand: "<invalid>" fast_charger_present: false fast_charger_type: "<invalid>" ideal_battery_range: 276.57 managed_charging_active: false managed_charging_start_time: null managed_charging_user_canceled: false max_range_charge_counter: 0 minutes_to_full_charge: 0 not_enough_power_to_heat: null off_peak_charging_enabled: false off_peak_charging_times: "all_week" off_peak_hours_end_time: 360 preconditioning_enabled: true preconditioning_times: "weekdays" scheduled_charging_mode: "Off" scheduled_charging_pending: false
ich bitte um eure hilfe.
wenn alles fertig ist würde ich ein How To schreiben. und im Wiki veröffentlichen.
