Entwicklung node-red-contrib-loxone für node-red
  • Tico
    • 31.08.2016
    • 1035
    I have done some more fault-finding and got things mostly working. I can see that something has changed in either Node-Red or the Lighting Block integration with Node-Red.
    Previously, when the Lighting Block was switched off, a value of hsv(0,0,0) was output from the Node-Red Control-In. This was recognised by a 3-way switch as follows -
Name: 3-way split.png
Ansichten: 1026
Größe: 43,2 KB
    The three-way switch doesn't work anymore for the Off selection. Now, when the Lighting Block is switched off, rather than hsv(0,0,0), the transition of a CW/WW value is as follows -
Name: Cool white to Off.png
Ansichten: 917
Größe: 13,3 KB
    The transition from a colour value to Off is as follows -
Name: Colour transitions.png
Ansichten: 908
Größe: 12,9 KB
    I've done a modification of the switch to adapt to the CW/WW transition to Off. I'm a bit stumped on how to adapt the colour transition to recognise that just the V (of HSV) has gone to 0. The HS component is constantly changing for different colours. Is the hsv(0,0,0) gone for good? Any suggestions on how to adapt the colour selection to Off transition?
Name: Modification of switch.png
Ansichten: 916
Größe: 50,9 KB
    • Tico
      Tico kommentierte
      Thank-you pmayer. The "matches regex" works well for colour. I am trying to adopt that for the "temp(0,x)" also. I obviously don't understand the complexities of regex. I've tried many variations of your example altered for temp. No luck.
    • pmayer
      pmayer kommentierte
      Try ^temp\(0,\d+\)$ (untested)
      You can evaluate suchs things with something like https://regex101.com/
    • Tico
      Tico kommentierte
      Perfect. Thanks for the link.
  • pmayer
    • 27.02.2017
    • 379
    0.10.7 wurde gerade released.
    Es wurden ein paar Übersetzungsfehler und der keepalive-node gefixt.
    Wichtig: Da der Keepalive-Zyklus nun im Miniserver konfiguriert wird, muss diese Einstellung einmalig für den config-node nach dem Update eingestellt werden. Wenn es eine neue config ist, ist ein default Wert hinterlegt.
    Zuletzt geändert von pmayer; 09.06.2020, 10:32.
    https://allgeek.de/
    • aw_ch
      • 15.08.2017
      • 66
      hallo zusammen
      Node-red läuft bei mir mit Loxone schon einige Zeit, um verschiedene andere Systeme zu integrieren. Seit dem Update auf von 0.10.4 (nicht mehr ganz sicher) auf 0.10.7 kann ich den node "Stream in" nicht mehr öffnen und konfigurieren. Die bestehenden StreamIn-nodes funktionieren noch, lassen sich aber auch nicht mehr bearbeiten. Wenn ich einen anderen node öffne und wieder schliesse, erscheint dann ein leeres StreamIn-Fenster, das sich aber auch nicht konfigurieren lässt (Raum und Kategorie sind leer).
      das Ganze läuft bei mir als Docker auf einer Synology DS518+. Getestet habe ich unter node-red 0.20.7 (aktuelle Installation) und node-red 1.0.6 (Testaufbau für anstehendes Update).
      • pmayer
        pmayer kommentierte
        Danke für die ganzen Infos. Testen wir morgen.
      • aw_ch
        aw_ch kommentierte
        Danke! Falls noch was benötigt wird oder getestet werden kann, einfach melden.
      • 4257
      Teste mal damit:
Ansichten: 1118
Größe: 18,4 KB
      • aw_ch
        aw_ch kommentierte
        Die Kommunikation mit dem MS funktioniert bei mir ja grundsätzlich, die Elemente werden in den anderen Nodes auch korrekt angezeigt. Bestehende StreamIn-nodes funktionieren ja ebenfalls, lassen sich nur nicht mehr öffenen.
        Hast Du mal den Cache des Browser geleert oder einen anderen genommen? Ich hatte sowas auch schonmal. Lag ab Browser
      • aw_ch
        aw_ch kommentierte
        Das war mein erster Verdacht, ist aber auch mit anderem Browser / Rechner so. Zum testen habe ich ausserdem einen komplett neuen Docker-Container mit node-red aufgesetzt, auch hier war das verhalten gleich.
    • aw_ch
      • 15.08.2017
      • 66
      mir fällt grad noch ein, dass auf meinem MS noch Version 10 (10.2.3.26) läuft. Kann das etwas damit zu tun haben?
      • pmayer
        • 27.02.2017
        • 379
        Wir haben den Fehler mit dem Stream-In gefunden... Ist in 0.10.8 behoben.
        Wird heute im Laufe des Tages releaesed :-)
        https://allgeek.de/
        • pmayer
          pmayer kommentierte
          0.10.8 released
      • aw_ch
        • 15.08.2017
        • 66
        gerade gesehen, aktualisiert => läuft wieder perfekt.
        Dankeschön!
        • Lenardo
          • 602
          ich hab wieder mal eine Frage, wie kann ich mit red-node einen http request durchführen, ich hab es bisher in Loxone gelöst über den http Eingang, aber es gibt einige Dinge die ich in Loxone nicht auswerten kann und ich möchte es über red-node versuchen
          die seite wird mit ALLEN werten gelesen, aber wie bekomme ich jetzt die EINZELNEN werte raus ? was muss unter selector stehen ?
          Klicke auf die Grafik für eine vergrößerte Ansicht  Name: red-node-http request.png Ansichten: 0 Größe: 102,9 KB ID: 254036
          Zuletzt geändert von Lenardo; 14.06.2020, 17:31.
          • Xenobiologist
            Xenobiologist kommentierte
            Poste mal den Output des Dubug nodes und stell hier vorher complete Object ein.
        • Xenobiologist
          • 15.01.2016
          • 1116
          Was auf jeden Fall ginge, wäre ein function node und dann mit split und substr usw zu arbeiten.
          • Lenardo
            • 602
            Das kommt raus nach dem http request, Was müsste im Functions Node stehen und was im Split, nur ein Beispiel
            { ph_value = '9.02'; mv_value = '757'; temp_value = '25'; ph_alarm = 'true'; mv_alarm = 'false'; temp_alarm = 'false'; critical = 'false'; Ausgang = Array(0,0,0,0,0,0,0,0,0,0); Eingang = Array(0,0,0,0,0,1,0,0,0,1); status_http = 'Status: Dosierverzögerung 600s'; version = 'Version: 2.1.2'; date ='14.06.2020 18:15:34'; ph_set = Array(735,40,730,780); mv_set = Array(770,100,670,770); temp_set = Array(130,50,40,300); regelfunktion = '0'; o2_anzeige_tag = Array(0,0,0,0,0,0,0,0); o2_value = '0 ml' o2_fehler = 'false'; name_of_day = Array('Mo','Di','Mi','Do','Fr','Sa','So'); }
            Zuletzt geändert von Lenardo; 14.06.2020, 18:23.
            • pmayer
              • 27.02.2017
              • 379
              JSON-Node nehmen um die Payload in ein Objekt zu übertragen und dann mit
              msg.payload.ph_value
              (z.B.) zugreifen?
              https://allgeek.de/
              • Xenobiologist
                • 15.01.2016
                • 1116
                So ginge natürlich immer
                HTML-Code:
                [{"id":"bc993039.1b67c8","type":"inject","z":"efe5e3e7.5d641","name":"","topic":"","payload":"{ ph_value = '9.02'; mv_value = '757'; temp_value = '25'; ph_alarm = 'true'; mv_alarm = 'false'; temp_alarm = 'false'; critical = 'false'; Ausgang = Array(0,0,0,0,0,0,0,0,0,0); Eingang = Array(0,0,0,0,0,1,0,0,0,1); status_http = 'Status: Dosierverzögerung 600s'; version = 'Version: 2.1.2'; date ='14.06.2020 18:15:34'; ph_set = Array(735,40,730,780); mv_set = Array(770,100,670,770); temp_set = Array(130,50,40,300); regelfunktion = '0'; o2_anzeige_tag = Array(0,0,0,0,0,0,0,0); o2_value = '0 ml' o2_fehler = 'false'; name_of_day = Array('Mo','Di','Mi','Do','Fr','Sa','So'); }","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":600,"y":120,"wires":[["40d342c7.647d04"]]},{"id":"a6c47a03.a03748","type":"debug","z":"efe5e3e7.5d641","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":970,"y":120,"wires":[]},{"id":"40d342c7.647d04","type":"string","z":"efe5e3e7.5d641","name":"","methods":[{"name":"between","params":[{"type":"str","value":"ph_value = '"},{"type":"str","value":"';"}]}],"prop":"payload","propout":"payload","object":"msg","objectout":"msg","x":770,"y":120,"wires":[["a6c47a03.a03748"]]}]
                • Lenardo
                  Lenardo kommentierte
                  Ein Traum ! die Lösung von pmayer sieht sehr einfach aus und hab ich in unterschiedlichen Varianten auch vorher so gegoogelt, funktioniert aber leider nicht bei mir,-- deine String Lösung funzt sofort, Dankeschön !!
                  Ps: damit ist auch mein Hauptanliegen gelöst, im Eingang/Ausgangs Array liegen nämlich die Alarmmeldungen die ich nicht abgreifen konnte mit Loxone
                  Zuletzt geändert von Lenardo; 15.06.2020, 14:54.
                • pmayer
                  pmayer kommentierte
                  Ah, ok. Dann ist es aber dann kein valides JSON, sah für mich im ersten Moment so aus. War ja nur mal so in den Raum geworfen ;-)
                  Das in #520 ist JavaScript Notation.
              • Lenardo
                • 602
                red-node ist für mich die geilste Erfindung seit dem Vatertag ;-)
Name: red-node_http request.png
Ansichten: 703
Größe: 179,2 KB
                Zuletzt geändert von Lenardo; 19.06.2020, 11:03.
                • Damyt
                  • 20.11.2019
                  • 12
                  endlich meine Dimmer hinbekommen und nun habe ich ein unerwartetes Problem.
Ansichten: 864
Größe: 16,1 KB
Ansichten: 888
Größe: 24,3 KB
Name: loxone error.PNG
Ansichten: 826
Größe: 200,5 KB
                  Mir ist aufgefallen, dass dieser Verbindungsabbruch anfing als ich mich mit dem miniserver verbunden hatte um VI für die Rollosteuerung ein zu fügen.
                  Der PI ist über LAN verbunden und ich kann auch von dort direkt den MS anpingen.
                  node-red-restart , start, stop, Neustart PI half alles nichts.
                  NR 1.1.2
                  Loxone 11.0.5.5
                  Wäre für jede Unterstützung dankbar.
                  Danke EUch.
                  • pmayer
                    pmayer kommentierte
                    Hmm... die Fehlermeldung ist recht ungewöhnlich und ist mir so noch nicht begegnet. Welche Version von node-red-contrib-loxone hast du installiert?
                    Könnte es sein, dass Du von diesem PI aus weitere Verbindungen zum MiniServer öffnest? Also per WebREST usw.? Es wird versucht die Verbindung zum MiniServer aufzubauen und den Token zu nutzen. Allerdings kommt da schon sofort die Meldung, dass auf den Stream Daten gesendet werden, obwohl die Verbindung getrennt wurde. Könnte ein Zeichen dafür sein, dass die Firewall des MS den Pi blockiert.
                    Zugang in NodeRed auf die Loxone ist korrekt eingetragen?
                    Hatte das auch schon und musste die Daten neu eingeben bzw. könnte auch die Verschlüsselung falsch eingetragen sein.
                    Miniserver ein Update verpasst?
                • Damyt
                  • 20.11.2019
                  • 12
                  node-red-contrib-loxne ist 0.10.8
                  Ich wüsste nicht, das ich von dem PI noch irgendwelche Verbindungen an den MS habe oder etwas sende. Meine Flows funktionierten ja auch bis dato.
                  MS ist auf aktueller Version. Loxone 11.0.5.5
                  Ich habe Node Red (mit Root) danach komplett neu installiert mit allen notwendigen Nodes...sprich genauso wie vorher auch.
                  bash <(curl -sL https://raw.githubusercontent.com/no...js-and-nodered)
                  Das alles half nichts...imer noch connection closed.Dann hatte ich auch noch Probleme den HUB zu ereichen, was sich aber mit einem PI Neustart erledigt hatte.
                  Als ich abends versuchte mit dem damals (am NR) angemeldeten Benutzen einen HTTP Request an meinen MS zu senden (wollte VI am Rollo schalten), fiel mir auf, dass dieser (auch in NR) eingetragene Benutzer wohl erstmal eine Pause einlegen sollte.
                  HTTP Antwort war:
                  403 Forbidden User XXX temporarily blocked, too many failed login attemps; 388 -> dieser Counter lief auf null im Sec. Takt runter und ist dan sofort wieder auf max. gesprungen.
                  Ich konnte mich mit diesem Benutzer auch nicht mehr über die Loxone APP anmelden.
                  Also habe ich diesen entfernt und einen neuen "Sprachassistent" angelegt. Encryption und Keepalive habe ich wie auch damals so belassen.
Ansichten: 1026
Größe: 50,1 KB
                  siehe da, ich konnte mich verbinden... allerdings hielt die Freude nur kurz, denn nun springt der Status zwischen connected und connection closed. ziemlich genau im 15sec.Takt
                  hier noch mal was passiert, wenn ich im LXTerminal NR stope und starte
                  pi@raspberrypi:~ $ node-red-stop
                  Stop Node-RED
                  Use node-red-start to start Node-RED again
                  pi@raspberrypi:~ $ node-red-start
                  #Start Node-RED
                  Once Node-RED has started, point a browser at http://192.168.188.50:1880
                  On Pi Node-RED works better with the Firefox or Chrome browser
                  Use node-red-stop to stop Node-RED
                  Use node-red-log to view the recent log output
                  Use sudo systemctl enable nodered.service to autostart Node-RED at every boot
                  Use sudo systemctl disable nodered.service to disable autostart on boot
                  To find more nodes and example flows - go to http://flows.nodered.org
                  Starting as a systemd service.
                  15 Jul 09:24:35 - [info]
                  Willkommen bei Node-RED!
                  15 Jul 09:24:35 - [info] Node-RED Version: v1.1.2
                  15 Jul 09:24:35 - [info] Node.js Version: v10.15.2
                  15 Jul 09:24:35 - [info] Linux 4.19.97-v7l+ arm LE
                  15 Jul 09:24:37 - [info] Paletten-Nodes werden geladen
                  15 Jul 09:24:39 - [info] Dashboard version 2.23.0 started at /ui
                  15 Jul 09:24:40 - [info] Einstellungsdatei: /root/.node-red/settings.js
                  15 Jul 09:24:40 - [info] Kontextspeicher: 'default' [ module=memory]
                  15 Jul 09:24:40 - [info] Benutzerverzeichnis: /root/.node-red
                  15 Jul 09:24:40 - [warn] Projekte inaktiviert: editorTheme.projects.enabled=false
                  15 Jul 09:24:40 - [info] Flow-Datei: /root/.node-red/flows_raspberrypi.json
                  Die Datei mit den Datenflowberechtigungsnachweisen wird mit einem vom System generierten Schlüssel verschlüsselt.
                  Wenn der vom System generierte Schlüssel aus irgendeinem Grund verloren geht, werden Ihre Berechtigungsnachweise
                  Die Datei kann nicht wiederhergestellt werden. Sie müssen sie löschen und erneut eingeben.
                  Ihre Berechtigungsnachweise.
                  Sie sollten Ihren eigenen Schlüssel mit Hilfe der Option 'credentialSecret' in
                  Ihre Einstellungsdatei. Node-RED wird dann Ihre Berechtigungsnachweise erneut verschlüsseln.
                  Datei mit dem ausgewählten Schlüssel beim nächsten Deployen einer Änderung verwenden.
                  15 Jul 09:24:40 - [info] Flows starten
                  15 Jul 09:24:40 - [error] [loxone-miniserver:35b5c900.6105d8] missing credentials for 192.168.178.77:50666
                  15 Jul 09:24:40 - [error] [loxone-miniserver:168e3e5a.673782] missing credentials for 192.168.178.77:50666
                  15 Jul 09:24:40 - [info] Flows gestartet
                  15 Jul 09:24:40 - [info] Server wird jetzt auf http://127.0.0.1:1880/ ausgeführt.
                  15 Jul 09:24:40 - [info] [loxone-miniserver:bb6b238c.96f2d] Miniserver connected (192.168.188.59:80) using Token-Enc
                  15 Jul 09:24:40 - [info] [loxone-miniserver:95f80fc8.77aa4] Miniserver connected (192.168.188.59:80) using Token-Enc
                  WebSocket error: Socket Error: undefined ERR_STREAM_WRITE_AFTER_END 1006
                  15 Jul 09:24:40 - [error] [loxone-miniserver:95f80fc8.77aa4] Miniserver connection error: Socket Error: undefined ERR_STREAM_WRITE_AFTER_END (1006)
                  Websocket Connection closed: 1006 Socket Error: undefined ERR_STREAM_WRITE_AFTER_END
                  15 Jul 09:24:40 - [info] [loxone-miniserver:95f80fc8.77aa4] connection closed: Socket Error: undefined ERR_STREAM_WRITE_AFTER_END (1006)
                  15 Jul 09:24:40 - [info] [loxone-miniserver:95f80fc8.77aa4] connection closed: reconnecting
                  15 Jul 09:24:40 - [error] [loxone-miniserver:bb6b238c.96f2d] Miniserver connection error: Socket Error: undefined ERR_STREAM_WRITE_AFTER_END (1006)
                  15 Jul 09:24:40 - [info] [loxone-miniserver:bb6b238c.96f2d] connection closed: Socket Error: undefined ERR_STREAM_WRITE_AFTER_END (1006)
                  15 Jul 09:24:40 - [info] [loxone-miniserver:bb6b238c.96f2d] connection closed: reconnecting
                  15 Jul 09:24:41 - [info] [loxone-miniserver:bb6b238c.96f2d] got structure file 2020-07-15 07:40:44
                  15 Jul 09:25:10 - [error] [loxone-miniserver:95f80fc8.77aa4] Miniserver connection error: Socket Error: undefined ERR_STREAM_WRITE_AFTER_END (1006)
                  15 Jul 09:25:10 - [info] [loxone-miniserver:95f80fc8.77aa4] connection closed: Socket Error: undefined ERR_STREAM_WRITE_AFTER_END (1006)
                  15 Jul 09:25:10 - [info] [loxone-miniserver:95f80fc8.77aa4] connection closed: reconnecting
                  15 Jul 09:25:10 - [info] [loxone-miniserver:95f80fc8.77aa4] Miniserver connected (192.168.188.59:80) using Token-Enc
                  Websocket Connection closed: 1000 normally closed
                  15 Jul 09:25:11 - [info] [loxone-miniserver:95f80fc8.77aa4] connection closed: normally closed (1000)
                  15 Jul 09:25:11 - [info] [loxone-miniserver:95f80fc8.77aa4] connection closed: reconnecting
                  15 Jul 09:25:11 - [info] [loxone-miniserver:95f80fc8.77aa4] Miniserver connected (192.168.188.59:80) using Token-Enc
                  15 Jul 09:25:12 - [info] [loxone-miniserver:95f80fc8.77aa4] connection closed: normally closed (1000)
                  15 Jul 09:25:12 - [info] [loxone-miniserver:95f80fc8.77aa4] connection closed: reconnecting
                  15 Jul 09:25:12 - [info] [loxone-miniserver:95f80fc8.77aa4] Miniserver connected (192.168.188.59:80) using Token-Enc
                  15 Jul 09:25:13 - [info] [loxone-miniserver:95f80fc8.77aa4] connection closed: normally closed (1000)
                  15 Jul 09:25:13 - [info] [loxone-miniserver:95f80fc8.77aa4] connection closed: reconnecting
                  15 Jul 09:25:13 - [info] [loxone-miniserver:95f80fc8.77aa4] Miniserver connected (192.168.188.59:80) using Token-Enc
                  Websocket Connection closed: 1002 Control frames must not be fragmented.
                  15 Jul 09:25:13 - [info] [loxone-miniserver:bb6b238c.96f2d] connection closed: Control frames must not be fragmented. (1002)
                  15 Jul 09:25:13 - [info] [loxone-miniserver:bb6b238c.96f2d] connection closed: reconnecting
                  15 Jul 09:25:13 - [info] [loxone-miniserver:bb6b238c.96f2d] Miniserver connected (192.168.188.59:80) using Token-Enc
                  15 Jul 09:25:13 - [error] [loxone-miniserver:bb6b238c.96f2d] Miniserver connection error: Socket Error: undefined ERR_STREAM_WRITE_AFTER_END (1006)
                  15 Jul 09:25:13 - [info] [loxone-miniserver:bb6b238c.96f2d] connection closed: Socket Error: undefined ERR_STREAM_WRITE_AFTER_END (1006)
                  Das ist sehr nervig.
                  Ich danke Euch.
                    Bei mir hab ich folgendes eingestellt und nicht den Token obwohl der aktuell sein sollte: AES-256-CBC
                  • Damyt
                    Damyt kommentierte
                    Umstellung auf AES-256-CBC ändert leider nichts.
                    Zuletzt geändert von Damyt; 15.07.2020, 10:08.
                  • pmayer
                    pmayer kommentierte
                    Token-Enc ist ab Lox 9 richtig, wie's im gelben Kasten steht ;-)
                    @AlexAn: Irgendwann wird AES nicht mehr funktjonieren.
                    @Damyt: Irgendwas beendet da die Verbindung. Stell mal bitte das Keepalive kürzes (10s) und guck mal was dann passiert.
                    ERR_STREAM_WRITE_AFTER_END macht mich halt grade stutzig... ist mir so noch nicht begegnet.
