Problem dimmer vs detector NC
    In the toiler upstairs i have a detector (nc that goes on and off several times while in the toilet)) and the light is connected to the loxone dimmermodule. Between 7.00 and 22.00 it needs to light up at 100% for 3 minutes and between 22.00 and 7.00 it needs to light up at 30%
    it Always worked fine until i did a software update. My loxone is on of the first made and i very mutch love it !!
    Same problem in the nighthall : 2 NC detectors, one dimmer output, and one light sensitive outside switch. Between 7.00 and 22.00 and if it is dark outside th lights need to dim on to 100% for 3 minutes. Between 22.00 and 7.00 at 30%. It Always worked fine until the update ...
    thanks for the help.
