Loxberry auf Hyper-V Installation - Sonos4Lox
  • logol01
    • 03.03.2018
    • 832
    habe genau nach dieser Anleitung Loxberry auf einer Hyper V Installation gespielt.
    (Version 0.2.3)
    Danach habe ich das Sonos4Lox Plugin (Zip Datei) unter Plugins installiert - (Version 3.4.1)
    was ein wenig komisch ist, dass folgende Meldung im Logfile kommt:
    <INFO> Command: /bin/sh "/tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh" "nM9KUn1p7N/LoxBerry-Sonos-3.4.1" "Sonos" "sonos4lox" "3.4.1" "/opt/loxberry" /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: 58: /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: cannot create /system/samba/smb.conf: Directory nonexistent /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: 59: /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: cannot create /system/samba/smb.conf: Directory nonexistent /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: 60: /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: cannot create /system/samba/smb.conf: Directory nonexistent /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: 61: /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: cannot create /system/samba/smb.conf: Directory nonexistent /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: 62: /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: cannot create /system/samba/smb.conf: Directory nonexistent /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: 63: /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: cannot create /system/samba/smb.conf: Directory nonexistent /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: 64: /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: cannot create /system/samba/smb.conf: Directory nonexistent /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: 65: /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: cannot create /system/samba/smb.conf: Directory nonexistent /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: 66: /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: cannot create /system/samba/smb.conf: Directory nonexistent /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: 67: /tmp/uploads/nM9KUn1p7N/LoxBerry-Sonos-3.4.1/postinstall.sh: cannot create /system/samba/smb.conf: Directory nonexistent <OK> Skript ohne Fehler ausgeführt <INFO> Aktualisiere Systemmenüs <OK> Systemmenüs aktualisert <INFO> Räume auf und lösche temporäre Dateien <OK> Installation erfolgreich abgeschlossen!
    Wenn ich nun im Home Screen von Loxberry auf das Plugin Sonos gehen möchte kommt der Fehler: "Error loading Page". Woran kann das liegen?
    Viele Grüße Logol01
    • 11238
    Diese Version des Sonos-Plugins ist nicht mit LoxBerry 0.2.3 kompatibel. Steht groß rot oben im Sonos-Wiki-Artikel.
    • logol01
      • 03.03.2018
      • 832
      Hallo Christian,
      jetzt habe ich es auch kapiert.....
      DANKE. Wer lesen kann ist klar im Vorteil.
      Aber wie bekomme ich auf die Hyper-V Installation nun ein Update von 0.2.3 auf die Version 1.0.x hin?
      Die Hyper-V Images gibt es nur bis zur Version 0.2.3.
      VG
      Logol01
        • 11238
        Leider garnicht.
        LoxBerry ist für Raspberry Pi entwickelt.
        Die VMs werden von anderen auf Basis der Image-Anleitung erstellt, und das ist bisher für LB 1.x nicht passiert.
        Wenn du nicht Linux-Experte bist, ist es das beste, du kaufst dir einen Pi.
        lg Christian
        • logol01
          • 03.03.2018
          • 832
          Hallo Christian,
          Danke! Habe mir eben so nen Rasperry Pi bestellt.
          Mal sehen ob das der Buchhändler bis morgen schafft.
          Und Danke das Du immer so schnell hilfst.
          Logol01
