Sonos brechen
    Sonos brechen
    Hallo, Sorry für die schlechte Deutsch Ich suche mit Google zu helfen! Ich habe über die Entsendung von der Englisch -Forum ohne Erfolg versucht. Hat jemand kommen mit einem Weg, um Musik auf Sonos brechen , spielen Klingel -Sound, dann wieder , was auch immer spielte , bevor ? dank James
  • Liver_64
    • 07.09.2015
    • 602
    Try in English, maybe i can help you
      I'm trying to get my doorbell over sonos to interrupt any music being played and then resume playing music again once finished. At the moment it will stop the music and play the doorbell but that is as far as i have got.
      • Matthias
        • 06.09.2015
        • 198
        I am also interested in such a solution.
        At the moment I know only 2 options, either using Raspberry or C3 Gateway.
        Both should work as you explained but C3 is very expensive.
        • Florian
          Loxonaut
          • 24.08.2015
          • 127
          Third option:
          use a Loxone Music Server and use the Sonos speaker as an UpNp Zone.
          That way you can have Text To Speech, Doorbell, Alarm, Airplay (!) via your Sonos speakers.
          Florian
          • Matthias
            • 06.09.2015
            • 198
            You are fully right Florian, how could I forget the Musik Server :-)
              • 6320
              Maybe because the music server is to expensive? ;-)
              • Matthias
                Matthias kommentierte
                Thats the main reason and additionally I do have only wireless speakers. :-)
            • Liver_64
              • 07.09.2015
              • 602
              Just Loxone and Sonos doesn't work because you need to store infos pushed back from Sonos somehow. Loxone Music Server and C3 is too expensive if you previously own a Sonos System.
              You need minimum a Web Server Running php like Raspberry and then check out the various PHPSonos.inc solutions available.
              I use some coding from
              Mit einer Sprachausgabe fängt das Smart Home erst richtig an zu "Leben". So habe ich das ganze zusammen mit dem Loxone Miniserver realisiert.
              and
              Wrapper for PHPSonos. Contribute to ThomasTr/Sonos development by creating an account on GitHub.
              There is also a real complex Solution available
              A PHP library for interacting with Sonos speakers. Contribute to duncan3dc/sonos development by creating an account on GitHub.
              Actually i can control each speaker, play files, doorbell, phonebell and Text-to-Speech messages
                • 5161
                Why not?
                Example see old Loxone Forum #10 #21 #24
                lg Romildo
                  Thanks everyone for the reply's they have been really helpful.
                  As other have mentioned the Loxone music server and C3 gateway are too expensive to justify.
                  I think I am going to try Raspberry Pi method Liver_64 recommended.
                  What did you take from http://www.nikolaus-lueneburg.de/201...kann-sprechen/?
                  Is all the functionality not contained in https://github.com/ThomasTr/sonos?
                  romildo I think the method you described (I may be wrong as my German is not great) using just Loxone and Sonos doesn't save any previous state from Sonos then return to this after the 'Doorbell' is played. It just plays a radio station after the doorbell is played?
                    • 5161
                    I’m so sorry. I don’t remember exactly, but I’m sure in old forum there was a theme like this, only with Sonos and Loxone. I couldn’t found it anymore. At the moment I don’t have a Sonossysteme to play with.
                    If you want to use a Raspberry, I think this way have much more possibilities and it’s easier to find Information about that
                    lg Romildo
