Hänge mal jeden einzelnen Node aus dem anderen Flow (mit dem Webservice) an den Debug-Node und stell dort auf complete Object um.
Dann sollte man sehen, wir weißt du kommst.
Ansonsten könnten wir morgen auch mal per Teamviewer draufgucken.
[{"id":"793638e5.b507c8","type":"tab","label":"HK Garagentor","disabled":false,"info":""},{"id":"ebe49b96.4b976","type":"loxone-control-in","z":"793638e5.b507c8","name":"Garagentor Position","miniserver":"bda880d5.2d4e98","control":"13aa88f4-0383-9bdf-ffffd7795102f6f8","state":"13aa88f4-0383-9bdd-ffff1d107481ddac","x":130,"y":260,"wires":[["86a05ed9.be9ea8"]]},{"id":"541f3a8c.f66964","type":"loxone-control-in","z":"793638e5.b507c8","name":"Garagentor aktiv","miniserver":"bda880d5.2d4e98","control":"13aa88f4-0383-9bdf-ffffd7795102f6f8","state":"13aa88f4-0383-9bdc-ffff1d107481ddac","x":120,"y":140,"wires":[["2f802a89.264736"]]},{"id":"9870952f.6843c","type":"loxone-control-out","z":"793638e5.b507c8","name":"Tor auf","miniserver":"bda880d5.2d4e98","control":"15797853-0146-0b86-ffffd7795102f6f8","x":1010,"y":220,"wires":[]},{"id":"69226b8c.22ab04","type":"homekit-service","z":"793638e5.b507c8","isParent":true,"bridge":"46224d5f.ea4aec","parentService":"","name":"Garagentor","serviceName":"GarageDoorOpener","topic":"","filter":false,"manufacturer":"Default Manufacturer","model":"Default Model","serialNo":"Default Serial Number","firmwareRev":"","hardwareRev":"","softwareRev":"","cameraConfigVideoProcessor":"","cameraConfigSource":"","cameraConfigStillImageSource":"","cameraConfigMaxStreams":"","cameraConfigMaxWidth":"","cameraConfigMaxHeight":"","cameraConfigMaxFPS":"","cameraConfigMaxBitrate":"","cameraConfigVideoCodec":"","cameraConfigAudioCodec":"","cameraConfigAudio":false,"cameraConfigPacketSize":"","cameraConfigVerticalFlip":false,"cameraConfigHorizontalFlip":false,"cameraConfigMapVideo":"","cameraConfigMapAudio":"","cameraConfigVideoFilter":"","cameraConfigAdditionalCommandLine":"","cameraConfigDebug":false,"cameraConfigSnapshotOutput":"disabled","cameraConfigInterfaceName":"","characteristicProperties":"{"CurrentDoorState":0}","waitForSetupMsg":false,"outputs":2,"x":590,"y":260,"wires":[["523ce22f.e21be4"],[]]},{"id":"86a05ed9.be9ea8","type":"function","z":"793638e5.b507c8","name":"HomekitHandler","func":"// Use the change and value in position to calculate HomeKit commands\n\nvar GarageDoor = global.get("GarageDoor") || {};\n\n\nvar position = msg.payload\nvar output = null\n\n\n\nif (position == 1) {\n GarageDoor.state = "OPEN"\n GarageDoor.target = 0\n output = {\n "payload": {\n "TargetDoorState": 0,\n "CurrentDoorState": 0\n }\n }\n}\nelse if (position == 0) {\n GarageDoor.state = "CLOSED"\n GarageDoor.target = 1\n output = {\n "payload": {\n "TargetDoorState": 1,\n "CurrentDoorState": 1\n }\n }\n}\nelse if (position < GarageDoor.position) {\n GarageDoor.state = "CLOSING"\n GarageDoor.target = 1\n output = {\n "payload": {\n "TargetDoorState": 1,\n "CurrentDoorState": 3\n }\n }\n}\nelse if (position > GarageDoor.position) {\n GarageDoor.state = "OPENING"\n GarageDoor.target = 0\n output = {\n "payload": {\n "TargetDoorState": 0,\n "CurrentDoorState": 2\n }\n }\n}\nelse {\n GarageDoor.state = "STOPPED"\n // in HK STOPPED is displayed as OPEN\n GarageDoor.target = 0\n output = {\n "payload": {\n "TargetDoorState": 0,\n "CurrentDoorState": 4\n }\n }\n}\n\nGarageDoor.position = position\nglobal.set("GarageDoor", GarageDoor);\n\nreturn [output, {"payload": GarageDoor}]\n\n\n\n\n","outputs":2,"noerr":0,"initialize":"","finalize":"","x":380,"y":260,"wires":[["69226b8c.22ab04"],[]]},{"id":"f1e9d7fe.0e3fd8","type":"function","z":"793638e5.b507c8","name":"ActionHandler","func":"// Resend last position on stop of movement so we can detect \n// if door has stopped but is not in end position\n\nvar GarageDoor = global.get("GarageDoor") || {};\n\nGarageDoor.action = msg.payload\nif (msg.payload == 0) {\n // send last positon once more so we can detect STOP\n msg.payload = GarageDoor.position\n return msg;\n}\n\nreturn null\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":500,"y":140,"wires":[["86a05ed9.be9ea8"]]},{"id":"2f802a89.264736","type":"delay","z":"793638e5.b507c8","name":"","pauseType":"delay","timeout":"100","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":310,"y":140,"wires":[["f1e9d7fe.0e3fd8"]]},{"id":"523ce22f.e21be4","type":"function","z":"793638e5.b507c8","name":"HK2Loxone","func":"// HomeKit Values to Loxone Commands\n\nvar GarageDoor = global.get("GarageDoor") || {};\ntarget = GarageDoor.target\n\n// do not resend target else door will stop\n\nif (msg.payload.TargetDoorState == 0 && target != 0) {\n return [{"payload": "pulse"}, null]\n} \nelse if (msg.payload.TargetDoorState == 1 && target != 1) {\n return [null, {"payload": "pulse"}]\n}\n\nreturn [null, null]\n\n","outputs":2,"noerr":0,"initialize":"","finalize":"","x":790,"y":260,"wires":[["9870952f.6843c"],["96bca212.94e338"]]},{"id":"96bca212.94e338","type":"loxone-control-out","z":"793638e5.b507c8","name":"Tor zu","miniserver":"bda880d5.2d4e98","control":"16e6382b-0161-1384-ffffd7795102f6f8","x":1010,"y":280,"wires":[]},{"id":"9575cac9.86fac8","type":"comment","z":"793638e5.b507c8","name":"Eigene VIs zum öffnen und schließen","info":"Weil der Tor Baustein mit einem Visualisierungskennwort gesdhützt ist, werden eigen VI verwendet, die nur dem User NodeRed gehöhren.","x":980,"y":160,"wires":[]},{"id":"5f627d99.ca5764","type":"comment","z":"793638e5.b507c8","name":"Dieser Teil wird nur gebraucht um STOPPED korrekt anzuzeigen","info":"","x":310,"y":100,"wires":[]},{"id":"bda880d5.2d4e98","type":"loxone-miniserver","host":"192.168.178.230","port":"80","enctype":"0","active":true,"keepalive":"30000"},{"id":"46224d5f.ea4aec","type":"homekit-bridge","bridgeName":"Fasangasse","pinCode":"111-11-111","port":"","allowInsecureRequest":false,"manufacturer":"Node Red","model":"1.2.0","serialNo":"Default Serial Number","firmwareRev":"1.2.0","hardwareRev":"1.2.0","softwareRev":"1.2.0","customMdnsConfig":false,"mdnsMulticast":true,"mdnsInterface":"","mdnsPort":"","mdnsIp":"","mdnsTtl":"","mdnsLoopback":true,"mdnsReuseAddr":true,"allowMessagePassthrough":true}]
