Pre-Heat Up To Temperature & Overshoot
  • Jimmycooker
    • 25.11.2021
    • 7
    I have two questions i was hoping someone could help with:
    1.) Is it possible to prevent / disable the 'intelligent' / 'learning' heat up time function when scheduling heat? I just want Loxone to turn on heat to a radiator according to shcedule without desired setpoint temperature being reached (i have no temperature feedback in this room, and they are towel radiators i want to come on in the morning).
    2.) One of my rooms overshoots by 2 degrees due to size of cast iron radiators. Is it possible to tune the heating controls so that they reduce the rate of hot water supply sooner or from a larger deltaT?
    Thanks,
    James.
    • 11238
    With Ths you can adjust the pre-heat time (simply set 1).
    To speed up the controller, you might set a lower PWM time by parameter Tpwm.
