*Save the date!* Loxone Config & App 13.1 - 19.10.2022 UND 5 neue Produkte! 😱
Es kam doch meistens Ende März ein Release. Denke mit v14 wird das Release angekündigt. Neue Features scheint es wenig zu geben, vielleicht nennt Loxone es stability-Release oder so -
Release scheint vor der Tür zu stehen...
Changelog ist von den letzten Betas zusammengefasst in der heutigen Version.
Code:14.0.3.24 ---------------- New - BG-T2758 Added Commissioning Mode feature binaries for the following devices - Miniserver (Version 13.03.01.15) - Miniserver Compact (Version 13.03.01.15) - Tree Extension (Version 13.03.01.24) - LED Spot RGBW Tree (Version 13.03.01.15) - LED Spot WW Tree (Version 13.03.01.15) - LED Ceiling Light RGBW Tree (Version 13.03.01.15) - LED Pendulum Slim Tree (Version 13.03.01.15) - LED Ceiling Spot RGBW Tree (Version 13.03.01.15) - LED Ceiling Spot WW Tree (Version 13.03.01.15) - We want to give the installer direct feedback and a better overview wether the tree connection is faulty or not. - Lighting devices will now visually provide information whether the tree connection between tree extension and device is ok or faulty, when they are not paired with the miniserver. - A "OK" connection is indicated by white light (with additional green led ring in case of RGBW-Spots, Pendulum, etc.), a faulty connection is indicated by either no light (WW-Devices) or a red light (RGBW Devices). - Config Performance Improvements - Faster startup (50% faster) - Faster document open/close (60% faster) - Faster object insert (80% faster) - Faster document tree update - Less idle CPU usage in opened project view - Faster edit - Faster save to Client/Gateway - General performance improvements - Faster save to Client/Gateway, Save is now done asynchronous in multiple threads - Faster Paste - Fast Select - A3D9-T993 Backup in background - Window can be closed/minimised - A3D9-T993 SD format in background - New function block Spot Price Optimizer - Activate a load at times where your energy price is cheapest - A3D9-T928 Energy Flow Monitor: Name & Icon of residual value - A3D9-T904 NFC Code Touch function block validity options for NFC tags and codes - A3D9-T905 Device Count for Modbus - A3D9-T853 Added additional authentication configuration for the user and an text input for the access controller - A3D9-T902 New NFC Authentication Types (Code or NFC, 2FA, NFC, Code) - A3D9-T895 Added scroll function for info pinner - A3D9-T886 Added comparison of inputs for status block - Comparing inputs by writing e.g. <v1> in the value field (similar to the Status-text field) - Comparing text inputs with numerical operators (<, <=, >, >=) is not supported - Conversion of Utility Meter to new block via context menu - A3D9-T870 Info banner when client project is open - A3D9-T575 Added excel sheet that lists power usage - A3D9-T109 Project Planning is resized to screen size, if screen size is smaller than the default planning tool size - A3D9-T266 AutoSave for project planning tool - A3D9-T574 Automatic connection of multiple selected equal inputs - Reset Miniserver to factory settings from context menu - Belimo auto-Addressing dialog - Audio Player: New input Custom sound for playing event files - A3D9-T906 New parameters, Vs for the Mixing Valve Controller and Ps for the Intelligent Temperature Controller (same as IRC valve stand still) - A3D9-T289 Tooltip when creating a new trust - A3D9-T585 Added web service for longitude, latitude and sea level - miniserver/dev/sps/setlocation?latitude=48&longitude=14&sealevel=572 - miniserver/dev/sps/setlocation?longitude=14&sealevel=572 - miniserver/dev/sps/setlocation?latitude=48 - Search of Miniservers - Possibility to enter IP address range for IP scan - A3D9-T841 Weather Data is requested as a zip file - Project Planning: Added new spots - LED Ceiling Spot RGBW Tree: 100503, 100504 - LED Ceiling Spot WW PWM: 100505, 100506 - BG-I20674 Sauna Controllers: Added new input 'On' - A3D9-T925 New Systemmessage reporting device updates available with the possibility to start the updates directly. - A3D9-T1 Devices no longer update during pairing. Only during the desired AutoUpdate time (default 02:00) or manually via the device manager (context menu). - A3D9-T910 Editing icons in a multiple selection of function blocks is now possible (if the function block supports Icon editing) - A3D9-T648 Use same format for Loxone serial numbers in all places - New languages Vietnamese & Bulgarian - BG-T2794 Music-Player: add custom TTS-language - Trust: - Transfer of Manager role to another Miniserver - Transfer ownership of Users to another Miniserver - Error message when too many messages are sent - Communication improvements - Authentication NFC Code Touch: Added output for last authorised user, including Trust hostname if from another trust (without NFC ID) - BG-I21789 added online state object for HTTP VirtualIn objects - Modbus: - Adapted default polling cycle - Show register setting in red when nothing was entered - Valve Tree: improved status feedback on wrong cabling - Loxone Config 14.0 splash screen Fixed - General - Updated used Frameworks & Compilers - BG-I19288 Miniserver compact has wrong icon in multi edit dialog - BG-I19231 Project Planning: Wrong 'Under Bed' presence sensor added for new sleeping rooms - BG-I19314 Sauna Controller: Ready state not correctly using bench temperature and correction - BG-I19367 Comparison function block have problems with very small differences (0.001) resulting in invalid 'equal' result e.g. (1.001 & 1.002) - RN1-I767 Energy Manager: Value range not shown in tooltips - RN1-I773 Energy Flow Monitor: Unconfigured control not shown in app - Energy Flow Monitor: Not a favourite per default - Audioserver system status message: Confirm does not work - Trust: User tokens not invalidated when changing password on another trust member - DMX Extension: DMX device search bugfix - BG2-T259 Belimo: Sensor/Actor limitation is calculated on actual usage - BG2-T258 Belimo: show Addressing-Error in search-dialog - BG-I19419 Belimo: Systemmessage cannot be confirmed - Belimo: Malfunction/Maintenance handling - BG-I19891 IRC V1: typo in description of parameters Ths + Tcs - BG-I18809 local hostname not resolved always correctly when multiple ip addresses were in the dns answer - temp files were not deleted after routed network device update - increased timeout for routed network device update - Improved Statistic analysis for Version 2 statistics - BG-I18809 local hostname not resolved always correctly when multiple ip addresses were in the dns answer - BG-I18987 DMX Extension Page Clamp description cut off - BG-I18997 Internal Airbase has no Device-Information option - BG-I18592 Climate Control Selection Dialog reverts setting in Room Controller - BG-I19041 Modbus RTU: automatically set stop-bits based on parity - BG-I19025 Music Server Zone: API-connector-line drawn with offset - BG-I18288 Gate: state change of Ic not taken into account for last driven direction - BG-I19160 Climate Controller limC cant be set higher than limH - BG-I18993 Starting Monitor in dialog not working - BG-I19159 Room/Category dialog favourite checkbox cant be unchecked - A3D9-T459 Remove confusing update message when loading from miniserver - BG-I19154 corrected UX of search button in Dali learning dialog during search is running - BG-I19277 Modbus Actors sent even if they are not used - BG-I18199 Sequence Control Dialog: new IF-formula causes incorrect indentations - BG-I18156 Sequence Control Dialog: "-" operator not spaced correctly - BG-I18910 Daytimer: output Mode renamed to "Om", show liveview without digits - BG-I19213 Connector-names cut off if room/category is too long - Power Supply & Backup: do not lock visu for common system messages - BG-I19333: Devicestatus: log file not shown when connected externally - BG-I17158 Sequence Controller: finished sequence shown as active - Miele@Home - States not updating - Energy consumption has no decimal places - Old installed files not deleted when installing Loxone Config over existing installation - BG-I19345 Invalid filter text - BG-I19495 Setting grid: border not correctly displayed - Monitor: Changing filter stops autoscroll - BG-I18025 API Connector Media Controller Double Click is not recognized by the API Input - BG-I17450 ITC AQl output calculation incorrect for cooling mode - BG-I19412 SMTP Mailer: invalid order of header-elements when adding attachments - BG-I6899 Analog Memory: edges caused by time-objects not handled by all connected controls - BG-I19514 Central Controls: lock via app does not lock all assigned controls - BG-I19524 Climate Controller: no automatic popup - BG-I19574 DeviceStatus: no channel-check for US and IL Channels - Switch: Activate remanence per default - Changelog dialog not properly sized - Converted Statistics file (e.g. Utility Meter) contains invalid timestamps due to errors in old files, causing wrong lifetime statistics - BG-I19272 Daylight savings: Client program reported as outdated - Modbus TCP: Some test commands not working, test commands not correctly displayed in monitor - Reworked Tree device search - Miniserver uses the list of devices which the Miniserver already has additionally to the active search - Miele@Home: Added user agent to API requests - BG-I19613 Message Boxes appear while converting energy monitor / utility meter - Miniserver does not respond to unicast search requests - Multi Edit dialog for IO cant be opened from program page - Control preset cant be multiedited - Port not set when replacing network device - BG-I20050 Add only one connection per object (Drag&Drop) - BG-I19957 Project Planning: Multi Extension causes a second power supply & backup - Update dialog fails when Miniserver changes its IP - BG-I19420 Device Status: Enocean devices displayed as offline - Enocean Actors displayed as dummy devices - BG-I19775 Virtual Output template: Answer property not saved - BG-I19680 Systemmessage: User can have visualisation limited - BG-I19695 Identify possible on 1-Wire device - BG-I19774 Saving template with @ in password - BG-I19769 API Actor not automatically connected to API output of block - BG-I19708 Documentation: Info Boxes not displayed correctly - BG-I20020 Ribbon: No separator between Link and Extension specific buttons - BG-I20127 Paste of devices not working after load from Miniserver - BG-I20118 Multiplicator: Light Group assignment gets lost - BG-I19917 Room assignment of devices get lost when adding project to gateway - BG-I19270 Custom icons not visible in Config since they are not colored by the app and therefore need to be in light colours - BG-I20048 Miniserver Configuration: Internal address is set to ip instead of hostname - BG-I20129 Statistics: Every Change (Expert) does not write an entry on day change - Miniserver unable to load project due to invalid object count - BG-I19702 Statistic files containing entries from other months - BG-I20053 Adapted power connector letters - BG-I19686 Program always shown as not identical when there is a duplicate KNX address - Endless loop when entering specific IP address scan range - BG-I20112 Invalid permissions when user is created via app - BG-I20309 Lightcontroller: remove from favourites changes order in config - BG-I20291 Power supply & backup dialog: prevent pasting of control characters - BG-I20232 Operating Time: adapted default name and object type name - BG-I20140 Miniserver Compact: new Tree Device-Bubble shown on wrong extension - Newly added user does not have any permissions to controls on a client - Power Supply & Backup: Systemmessage does not contain room of device - Audio Identify of Compact not working when Compact is a Client Miniserver - Belimo Monitor remains active after Loxone Config disconnect - Improved Config connection reliability - Improved performance of table view with large data - Improved performance of System status - Spot Price Optimizer uses too many time slots - Schedule: Mode not updating in visualisation - BG-I20384 Project view does not close after Miniserver search - BG-I20017 No Device-Command context menu for Tree to Air bridge - BG-I20014 Automatic rule: severity-levels not identical with custom system message - BG-I20013 Device Status: remove unsupported commands from 1-Wire-Extension - BG-I20083 DMX Device: invalid next dmx channel when using 1-actor-types - BG-I18129 HTTP Virtual Out only sent POST request when body data was provided - BG-I20023 updated address conflict message in Dali learn dialog - BG-I20421 NFC LearnDialog: Learning could be started even on unavailable devices - BG-I19848 fixed jumping scrollbar in tech doc viewer when there are multiple gifs present - BG-I19419 Belimo: Systemmessage cannot be confirmed - BG2-T261 Improved Belimo Addressing - Starting Miniserver search from project view while already a project is opened connects in the opened project - Audio Central: Client restart causes resend of tts command to Audioserver - BG-I18428 Tree2Air-Bridge: sleeping Touch&Grill goes offline when saving into Miniserver - BG-I18212 Touch&Grill: switching room not possible after inserting controls in a certain order - Touch&Grill: Wrong room assigned after dragging on page - BG-I15908 fixed inconsistency on Lighting Controller Circuit Naming - BG-I17217 Caller Service Add additional spam error message at too many calls - BG-I20744 Fixed tracker minimal time interval. Values below 21ms are considered as 0. - Fixed System message indicates that a device is updating even though the device is finished updating - BG-I20784 Fixed icon multi edit over shared properties window - BG-I17710 Fixed shading central restarts by itself after stopping via Pc - BG-I19537 / BG-I17772 Scene on a client can not be triggered by an object connection - BG-I20841 KNX Sensors not updated on page when showing/hiding error output - BG-I20836 Output on another Miniserver cant be switched anymore after it was switch via LiveView - A07R-I309 Documentation: Range not displayed for some IOs - 1-Wire Monitor: Entries have no level (data, error), making it difficult to filter - LiveView/Simulation: Removed value adjust via mouse drag - This caused unwanted changes of values in installations when trying to move a reference - Simplified printing project - Only one print action - Automatically select current selected page in print dialog - LiveView: Display correction only if there is enough space - Monitors not working when 'Position windows freely' mode is active - BG-I20874 Integrated blind shown as not configured - BG-I20872 Connection to API output not created properly when done via connection window - Tree search shows results without serial - BG-I20723 AutoConfig: Tunable White shown as RGBW - Burglar Alarm: Opening configuration dialog is necessary to update names of used sensors - BG-I20702 Added hostname including domain to LoxAPP3.json (if the Miniserver is on DHCP) - BG-I20708 LiveView/Simulation: Nothing displayed on inputs of status block - Fire and Water Alarm: Use more descriptive names IOs which cause an alarm - Same handling as Burglar Alarm - BG-I20785 Confirmed error messages are also shown in document trees - Miniserver serial cant be entered without colons - Connect dialog does not set external address when connecting to Miniserver without internal address - BG-I19126 fixed crash and address conflict resolution in Dali learning dialog - BG-I20025 fixed incorrect address check in Dali learning dialog - BG-I20722 Deactivated update available message for devices which are offline or have the version 0.0.0.0 - BG-I19530 Wallbox Gen. 1: Profile change during charging caused a jump in energy consumption for the newly selected profile - BG-I19669 Fixed copying of a value from the property window, when it's not pinned - Tree2Air-Bridge: Device-Webservice & Device-Info not executed - BG-I12602 Geiger Solidline: API-Output is created with conversion when command-output is used - BG-I20715 System Status: view jumps to top after confirming message - BG-I20691 Remote Air does not extend the presence - BG-I20546 Air learning help link not working - BG-I20447 Schedule: Inverted output invalid when starting manual timer - BG-I20729 Statistics: Removed handling to only write values to the statistic file if they have changed - Now values are always written in the defined interval - BG-I20701 Power Supply & Backup not displayed in energy flow monitor when user has no rights for it - BG-I20618 IR Module search not working - BG-I20719 Generic View Filtering: Improved search/filter when texts include special characters (:.;) e.g. for serial numbers which now contain a colon - BG-I20732 PicoC text output edge not reset - BG-I20565 Search does not give any results when starting it after opening project view - BG-I19639 Miele devices displayed offline even if they are online - BG-I20746 Burglar Alarm: Tracker entries and text output does not contain enough information to distinguish sensors - added device name or installation place, depending on if the device was renamed - Remote Connect: Connection establishment did timeout in some cases when ipv4 and ipv6 nameservers are available - BG-I20457 ensuring that text in monitors is always readable depending on background colour - BG-I20406 virtual command edit dialog did not request full url parameters - BG-I19681 ensure NFC learning command is also sent to battery driven Air devices - BG-I20030 only enable resolve conflict button in dali learning dialog when needed - BG-I20021 show error message when trying to add/assign dali device with already assigned address - Presence links are shown as memory object in the periphery tree - Miniserver Compact: too many audioserver-tasks started - BG-I20132 Device Learning: Automatic blinds offline after replace via app - Periphery tree filter: 'Do not use' shows items without room/category - Caption bar changes when connection gets lost in another document - BG-I19420 EnOcean devices displayed offline in device status - BG-I20545 Mouse over shows hidden tree extension on Miniserver compact - BG-I20555 Removed error message when using custom inputs for UDP port 7090 - BG-I20408 Setting Edit dialog shows non working links - BG-I20532 Project analysis: Shows duplicate address even though when port is different - Allow cloud dns connect with Serialnumber including colons - BG-I17800 Radio Buttons: Allow web service command 'next' & 'prev' - Too many old program files get deleted when saving to Miniserver - Activate watchdog for IO Task - BG-I20891 Wallbox g1: Charging Power is always 1kw - BG-I20911 Miniserver search when filter is active does not show items - BG-I20902 Manage SD card dialog: Text overlaps button - BG-I20910 EFM: Meters get lost when adding project to gateway - Config/Miniserver memory leaks - Dali: removed deprecated settings (RGBWAF channel assignment) - BG-I15822 Dali: Fade Rate gets invalid value after replace device - BG-I19373 NFC Code Touch: no app update if code expires shortly after creation - BG-I20909 Monitor: Keycode information not shown if "force preselection" is activated - BG-T2795 Miniserver-Replace: audioserver not paired with new device - BG-I20906 + BG-I20932: DMX Extension: Invalid values sent to actors - Actors not switching - BG-I21006 Search/Filter for Air serial numbers in Config - BG-I21051 Nano DI Tree: Not all information displayed on cover page - BG-I21003 Touch Surface Dialog: Max. material thickness not validated - BG-I21024 Known Issue dialog not opening on click - BG-I21039 API Command text in table cut off - BG-I21020 Touch Pure Flex: Initial value not set in Menu command - BG-I21052 Copy of KNX IO not possible even if Cut is possible - BG-I18945 Touch Pure Flex not selectable as output in alarm objects - Update: Miniserver Gen.1 Update not working due to too short timeouts - BG-I20949 EFM: Self Consumption output zero - BG-I20936 Miniserver replace: Connect to gateway not working without IP & Config crash when there is no Audioserver - Reworked device updates available system message - Tree Devices: Fixed CAN was not initialized properly during startup if 24 V was connected to CAN - BG-T2825 TreeBase: Fixed init sequence which lead to a non functional Tree2Air bridge - BG-I21069 Touch & Grill causing Black screen in App - BG-I20029 hide already learned Dali devices in learning dialog, except "new installation" option is checked - BG-I20745 name of learning Enocean device wasn't taken over correctly - BG-I20738 added serial number column in Enocean learning dialog devices list - BG-I20737 corrected highlighting of new learn data in Enocean learning dialog - BG-I20789 fixed authentication url with email address as user in VIN command learning dialog - BG-I21394 fixed incorrect highlighting in some special cases in VIN command learning dialog - BG-I21009 Api Command on status block not working - Energy Manager Gen.2: Lower prioritised analog load does not get turned off when there is enough power for higher prioritised analog load - Nano DI Tree: Text on cover page too long - Include Alpha Web Interface - Weatherstation: Removed unused hidden inputs - BG-I21146 Miniserver replace: Miniserver not identifying in search - BG-I21147 Miniserver replace: Continue with enter on credential page - BG-I16359 Chart View: X Label to the left is cut off (presence configuration dialog) - BG-I19470 New statistics write value 0 to statistics on reboot - BG-I19122 Poolcontroller: Automatic Designer texts not available in the app - BG-I21407 Connection flag creation: Page window is opened outside of view - BG-I21396 Reference shows more information button - BG-I21283 User created operating modes get high IDs - BG-I18438 Presence Sensor Overrun Time P reset after power cycle incorrect - BG-I20981 Tree search on a intercom on a client not working when intercom block is not inserted - BG-I21162 Part List: Power supply & backup missing - BG-I21234 Adapted air signal strength qualification - BG-I21199 Intercom Gen.1: iButton learning not possible - BG-I21338 Touch Pure Flex: Command on central function block (e.g. central shading) is not sent to all objects (only sent to the controls last selected in the app) - Emergency Button can't be triggered via API command - Touch Pure Flex: Value selection in config has a shorter timeout than the device - Config locks up when loading from Miniserver - Plugin dummy device state not updated when changing api user setting - BG-I21008: DMX device DMX actuator RGBW can't set type of actuator - BG-I21090: Project Analysis: show duplicate Address/Channel settings for Belimo + DMX - BG-I17846 IR Extension/Module Learning not working - BG-I21909 Tree filter dropdowns empty in new project - BG-I20562 better error message in case start command failed in NFC learning dialog - BG-I21100 corrected DMX default name assignment when inserting device via DMX learning dialog - BG-I19714 default name was not correctly propagated when left empty in 1-Wire learning dialog - BG-I21761 popup in table views caused close when clicking in empty area - BG-I21763 first opening of detached monitor window showed all monitors - BG-I21802 search kicked message dialog shown for air and tree even though search was not running - BG-I21453 Device Status: invalid online state for Sonnen-Battery - BG-I21756 System Message for failed certificate: add information about reachability of internet and cloud-server - Belimo: devices without serial not shown as dummy device - BG-I21809 Wallbox: relative metering doesn't work - Dali Monitor: - Data flow is slow - Show errors in colour - Fixed wrong direction - Dali devices not sorted by name in document tree - BG-I21165 Monitor: Cancelling loading still empties monitor - Dali: Readded off to Power-On options - BG-I17585 Parameter cant be edited anymore after being set via API command - BG-I21726 Tree diagnosis cant send data when monitor is running at the same time in a big installation - BG-I21686 Invalid search answer for app learning when searching in a gateway - Touch Pure Flex: Arrow commands executed twice when in pulse mode - Extension serial cant be entered with colons - BG-I17713 Switch of mode via LiveView not working when calendar is active - BG-I21486 “Don't show again” checkboxes are not remembered after installing new version - BG-I21599 Extension update starts without being started - BG-I21600 Remove sensitivity settings from inputs which currently don't support it - BG-I19005 No device type for Miniserver displayed - BG-I21706 Control Linking dialog: Memory leak and invalid display - BG-I21693 Shorter validity for Loxone Config tokens - BG-I21516 Object stays partially selected when unselecting in tree - BG-I21390 LiveView: Yellow line not correctly displayed when value is zero - API Command dialog: Wrong command preselected - BG-I21441 SubControls contain "hasControlNotes" flag - BG-I21550 No Info on control when used in system schematic - BG-I21548 Unstable config connection when searching for tree devices on a gateway - Certificate systemmessage: removed help link - BG-I21515 Page scrolling continues after page change - BG-I21532 Property window: Scroll jumps when window is updated - BG-I21536 Wrong selection after deleting device from device tree - BG-I21478 Miniserver not correctly rebooting after update - No warning when using a hostname for a client as internal address - Reduced debug Monitor outputs - BG-I21592 Plugins: Online state is not per default monitored - BG-I21542 MENU Api Command: Added more info about start value - "If the current value does not represent an option, the first option will be used as the start value." - Improved speed of insert of multiple references - BG-I21072: App access code on NFC Code Touch cannot be deactivated in the app - Presence Tree: invalid default parameter after creating - BG-I21580 Media Controller: always execute "change to mode" - BG-I20751 Media Controller: reset via double-click does not finish command list - BG-I20988 Remove unused sensibility settings for Modbus-Sensors - BG-I16157 Usermanagement: Automaticdesigner not visible after editing groups - IO Data serialised twice to xml for air devices - BG-I21399 Dimmer: Value Selection on touch pure flex does not start with actual value - BG-I21430 Page scroll jumps after editing name of page - BG-I21450 Identify from tree not stopped when clicking in empty area of tree - BG-I21070 Proxy not properly closed when using ssl - BG-I21467 Statistic dialog cant be closed with escape after deleting a statistic - Emergency Alarm shown as unconfigured when only Alarm input is used - BG-I21082 Meter reset not correct, when reseting multiple times - Project cant be opened anymore after learning devices - BG-I21209 Tree device learning: Identification of devices in Config not working - Generic Table: Delete empties wrong cell when table is filtered or sorted - Miniserver compact: duplicate audioserver after re-adding gateway client to document - BG-I21472 Belimo Devices: No "Monitor Online Status" Option - Updated installer - BG-I21487 Presence Control: Statistics Record Every Second - BG-I21966 DMX actors change room asignment to "do not use" - BG-I21808 fixed incorrect request when invoking test command on HTTP VirtualIn - BG-I21800 Integer block result was incorrect for negative values in some cases - Invalid dns domain name breaks LoxApp - BG-I21949 Output to Output connection via reference not completely deleted when deleting reference - BG-I22038 Config cant be closed after opening project planning file - BG-I21905 Config problems when drag and dropping incompatible files onto Loxone Config - Document is modified when double clicking objects - BG-I22221 'Switch (On/Off)' has option for statistics - BG-I21811 Test command button disappears from ribbon and does not reappear - BG-I22143 Energy Manager: Memory changes type to analog when connected to output - BG-I22227 System Schematic flag remains when copying control from another project - BG-I22034 Dali Config improvements (Missing setting updates, clearer info when device has no address, naming after learning,...) - BG-I21697 Fire and Water Alarm Output N is not set to 0 when Off input is used - BG-I21689 Alarm Chain Output gets triggered once too many - BG-I21607 Handling a group of API commands separated by & - BG-I21586 Fixed object type name for NFC Key-Tags - BG-I22183 Intelligent Room Controller: Presets for Roomtype not applied - BG-I21110 Custom System Message not shown for allowed Users which have no access to triggering control - BG-I18777 Apostrophe in Miniserver name breaks admin interface - BG-I22148 Template button in ribbon has no action - BG-I22050 Document tree collapses on undo - BG-I21747 Invalid connection when connecting multiple memory inputs with different types - BG-I22142 Merged object cant be edited in multi edit window - BG-I22018 Opening system schematic set document to modified - BG-I21923 Valve error system messages not shown anymore when device goes temporarily offline - BG-I22001 Miniserver search: Added miniserver configure button - BG-I22033 Room/Category dropdown not updated when loading from Miniserver - BG-I22051 Miniserver mDNS response invalid when many extensions are connected - IR Meter Reader Air (M-Bus): Before each readout, the firmware now sends a “SndNke” to always get the same response. - BG-I22068 Media Control Dialog: Escape does not close window - BG-I21465 Roof Window Shading: Output Op is switched on sequentially - BG-I22160 Modbus: Digital Actor Write Single register sends 0xFF00 instead of 1/0 - Duplicated systemmessage for virtual HTTP Input - Unable to set ipv6 address as external address - BG-I21471 KNX Extension on wrong parent when converting Gen.1 to Gen.2 Miniserver - BG-I21491 Formula block: Division by zero in unused If result also results in an error (e.g. "IF(I1>0;10/I1;10)") - BG-I21719 App Learning: Search not stopped in app when search on another client is started - BG-I21721 Device Information of Miniserver shows wrong DNS - BG-I21745 Edit dialog not opening anymore after inserting control (e.g. burglar alarm) - BG-I21752 Receive timeout of analog input not directly reported - BG-I21777 Tooltip does not disappear - BG-I22070 Trust User: Token get deleted after update from trust owner - BG-I21625 Document Tree: Invalid tree root item - BG-I21790 Forward slash not allowed in block names - New icon for extension search - BG-T2934 Reduced delay in device proxy - BG-I20111 NFC: Access denied in App with authentication type "NFC (only)" - Schedule modes are invalid after update - LoxAPP not generated for standalone Miniserver when saving to Miniserver - No Page displayed after deleting all pages - BG-I22245 Mode: Switch in Simulation not working - BG-I22297 Air Channel does not revert to correct original channel when frequency change, which was started via context menu, is aborted - BG-I22351 Config shows program not identical - BG-I20689 Intercom: Bell input is available when intercom originates from another trust member - Network device does not display any serial number when address is not entered - BG-I19874 System Message unclear when Tree left and Tree right are connected - BG-I21412 Tree Shortcut systemmessage does not disappear - BG-I22219 AI Extension: Inputs are sorted by name - BG-I22253 Selection of multiple controls not working when there is a connection reference - BG-I22294 Room/Category may overlap for controls with only 1 visible input or output - BG-I14516 Steak Thermo: show "no sensor connected" in monitor and liveview - BG-I22030 API commands work even when Disable input of function block is active - BG-I22078 & BG-I22078 Touch Flex: Updating configuration always completely resets button configuration (selected controls, show state,..) - BG-I22025 Runtime counter: Output not updating when unit parameter is changed - BG-I21810 Multiplicator: Users are shown as unsecure even when password was changed - BG-I21905 Config problems when drag and dropping incompatible files onto Loxone Config - Document is modified when double clicking objects - BG-I22221 'Switch (On/Off)' has option for statistics - BG-I21811 Test command button disappears from ribbon and does not reappear - BG-I22227 System Schematic flag remains when copying control from another project - BG-I22034 Dali Config improvements (Missing setting updates, clearer info when device has no address, naming after learning,...) - BG-I22494 Project Overview: Miniserver type not updated when project is saved - Initial line origin when creating connection reference - BG-I21190 Touch Pure Flex Air: Does not send humidity anymore - BG-I21693 Shorter config token age - BG-I22128 Monitor can't be stopped from within the Monitor dialog - BG-I22225 API commands: Value selection start value not taken over from selection switch - BG-I22311 Additional info text when creating trust key - BG-I20736 certain monitor types were stopped when starting learning dialog - BG-I22466 Intercommunication: Password gets corrupted when copying intercommunication object - Control references are not restored when cutting and pasting control - BG-I22530 Miniserver LED still reports error after caller systemmessage source gets deleted - Update dialog automatically put to background during udpate - BG-I21834 Sequence Controller Dialog: goto-commands update invalid when lines are wrapped - BG-I19373 NFC Code Touch: Missing app update if code expires - BG-I18796 NFC Code Touch Air: not possible to learn NFC tags via app when battery powered - BG-I21130 NFC Code Touch: Locked device also locks app user - BG-I22282 Show deaddress-warning before deleting belimo device - BG-I21579 Expert Mode: not possible to activate statistics - Wallbox Air/Tree: product variants not visible in quicksearch - QU1-I208 Miniserver conversion: Settings of moved IO's get lost - Program shows not identical after update - BG-I22325 Formula: Automatically remove line breaks - BG-I22350 Miniserver configuration: Dialog closed when pressing ENTER even when a textfield has the focus - BG-I22356 Opened dialog positioned to low so its behind taskbar - BG-I22315 Multi Connect with physical input and memory input: Hidden error output gets connection instead of input - Trust: Usercaption created on unnecessarily - BG-I22030 Disable does not disable API commands on all controls - BG-I22247 Room/Category dropdown on program page goes out of application - A07R-I328 Project documentation has missing settings - Further validate hostname on Miniserver Gen.2 and compact - Smaller edit and drawing issues - Miniserver usage not updated after delete/undo - Pages not correct after undo - Auto-Update on Miniserver Gen.1 not working due to high memory usage - Update is now downloaded directly to file when there is not enough memory available - New binaries (13.03.03.22) for Belimo Air/Tree (Fixing/Full support search by Serial Number) - BG-I22304 Air Base set to 'Auto' always does an auto learn of devices - Now it's only done when there is a dummy device - BG-I22606 Format dialog: Broken selection when selecting Miniserver Compact backup - Assertion when closing document - Error message during connection establish - Miniserver update available message not shown - WA1-T298 WallboxTree is not working on internal Tree bracnch of Miniserver Compact - BG-I22228 Modbusserver: Sensors are still polled after being deleted - Devices & Extensions - new Roomsensor Tree binary: activated CO2 autocalibration - new Valve Tree binary: changes to reference drive and position drive to 0% - IR Meter Reader Air: Reading out Elster AS1440 could result in frequently occuring system messages - new binary for Valve Actuator Tree: improved valve detection and force applied to valve - Multi Extension Air: Stability improvements of the digital inputs - Miniserver reboot loop after configuring Miniserver which contains an internorm blind - LED Ceiling Light RGBW Tree: Removed blink states of backwards LED on - added new binary for NFC Code Touch Air: - learn mode improvements - BG-I20383 NFC Code Touch: Code entry timeout loses preselection - BG-I19180 NFC Code Touch Air: Sleep mode doesn't cancel held buttons - added new binary for Touch Pure Flex Air and Tree - BG-I20726 Touch Pure Flex Air VALUESELECT not working - Timekeeping improvements - Valve tree - added reference drive after firmware update - fixed valve stuck messages - Increased force to fix "valve stuck" messages - Improved internal error handling - BG-T1593: Weatherstation Air V2 added new binary FW-Version 12040309, fixed power on reset - BG-T1594: PacketSafe Air added new binary FW-Version 12040309, fixed power on reset - new binary for touch air: fixed BG-I21230: Touch Air: Touch not working in/after learn mode - new binary for room sensor air (HW 2): fixed device not sending values in 24V operation - New binaries (13.02.12.21) for Belimo Air/Tree (Fixes and de-address unknown) - Nano2Relay Tree (HW version 2): fixed devices going offline sporadically - Lighting - BG-I12390 Lightgroups go off during restart if actor is not on same miniserver - BG-I18405 T5 stuck in light controllers - BG-I19185 TW Smart actor: invalid On/Off state in LiveView - BG-I19751 Light Controller: moods still mixed after saving new mood - BG-I19705 Central light: with Off the selection is not observed - BG-I18909 Lightcontroller: Moods with stored sequences cannot be triggered when changing output type - I17292 Brightness-Change in Master-Color not applied for daylight-control - BG-I19472 Unable to dim Smart TW actor - RN1-I661 Daylight-states not updated for non-smart-actors - BG-I17633 Actor sends invalid values after adding to light group - BG-I19472 On/Off state incorrect when solely using TW-actors - BG-I22074 Dialog: operating modes not sorted alphabetically - BG-I21869 Light-Actors cannot be deleted after light group is removed - BG-I21444 Activating daylight does not change active mood - Energy - BG-I19601 EFM: Name of node gets lost in client gateway systems - BG-I19103 Utility Meter add value on miniserver start - Energy Flow Monitor: Meter on Client does not send values to EFM - RN1-I961 Energy Manager: Runtime per day and Minimum runtime wrong unit in the app - BG-I19010 Energy Flow Monitor: Program not modified when changing setting in dialog - BG-I19217 Energy Manager: Load which uses more power than provided not handled correctly - Meters of Power Supply & Backup on a Client break the Energy Flow Monitor - BG-I20128 Energy Manager: Reordering breaks runtime variables - BG-I19719 Meter without dedicated Meter Reading does not apply offset - BG-I20090 EFM: Statistic of used Meter is disabled - Energy Manager: Analog load is not maxed out when its not drawing any power, therefore no additional loads get activated - BG-I19635 Power Supply & Backup: Does Not write statistics on Client - BG-I21569 Energy Monitor conversion: Connection loss breaks conversion - Energy Flow Monitor: Does not show info of how many objects are assigned - BG-I19635 Power Supply & Backup: Does Not write statistics on Client - BG-I21514 Energymanager: Overlapping Output Texts - Energy Manager: Output regulation not the same anymore as before resulting in activation of inactive loads with maximum (e.g. e-car when getting plugged in) - Energy Manager: Active load which does not use any power, gets deactivated as soon as another load uses power and power available for managing therefore goes to zero - Spot Price Optimizer: Shown in visualisation - BG-I21797 Power Supply Control: invalid output RST in documentation - BG-I19552 Energy Flow Monitor does not use description of function blocks - BG-I22060 Pulse Meters: First energy not added to day/month/year - BG-I21921 Bidirectional Meters: Automatic connect of production/delivery meter reading inputs not correct - BG-I21921 Bidirectional Meters: Automatic connect of production/delivery meter reading inputs not correct - BG-I22143 Energy Manager: Memory changes type to analog when connected to output - BG-I22287 Energy Manager: Minimum runtime of load is ignored when managing grid power with an analog load - BG-I22345 Energy Monitor: Import total output only visible after conversion - BG-I22373 Energy Manager: Used power of load ignored when not activated by energy manager - Energy Flow Monitor: Residual icon & name can be edited even when not enabled - BG-I21974 Wallbox: start/pause via app not possible when inverted input with additional logic is used - Wallbox: charging status not updated in app - Climate - BG-I20032 Intelligent Temperature Controller: override-inputs always shown english in visu - BG-I20281 Intelligent Temperature Controller: set default colour to type "climate" - BG-I20334 Climate Controller: untranslated text in app - BG-I20468 Intelligent Temperature control: outputs not activated after reboot of gateway client - BG-I18463 + BG-I20079 Intelligent Roomcontroller: fixed setpoint in fahrenheit converted incorrectly - BG-I17499 Intelligent Roomcontroller: window contact not considered in changes of outdoor-temperature - BG-I9282 Intelligent Roomcontroller: prepare heating ignored after first day of operating time with duration > 1 day - BG-I20451 Intelligent Temperature Control: state not updated after miniserver-reboot - BG-I18991 Intelligent Room-Controller: output value changed multiple times during shutdown of climate controller - BG-I20857: Climate Controller Dialog: Checkboxes not remaining - BG-I20793 Climate Controller: If setting ϑlimC and ϑlimH via own logic it still can be changed in the app - BG-I21225 IRC: Mode 3 doesnt take over the target temperature - BG-I21259 IRC: Liveview when using PWM Outputs not updated - BG-I20777 IRC: Reset to Default doesn't reset selected mode - BG-I20377 IRC: selected mode via app persists after connecting mode-input - BG-I20933 IRC: Error-Message for big difference comes immediately when manually starting comfort mode - BG-I21339 Climate Controller: missing remanence - BG-I22076 IRC Setting limits can be overruled with multi edit - Shading - Automatic Shading Central: Change direction while moving. - Automatic Jalousie: Invalid End Position for Full-Up-Movement in simulation - BG-I21637 Central Shade: direction change via T5 incorrect - BG-I21637 Central Shade: direction change via T5 incorrect - Automatic Jalousie: Invalid End Position for Full-Up-Movement in simulation - BG-I21606 Automatic Jalousie: Shading moves completely when two commands are sent in succession - BG-I21755 Automatic Shading Integrated: connecting a dummy motor causes infinite recalculation loop - BG-I21606 Automatic Jalousie: Shading moves completely when two commands are sent in succession - BG-I22402 Automatic Jalousie: allow pulse up/down commands via app - BG-I21926 Automatic jalousie: invalid behaviour in simulation when using Nano2Relay tree - Belimo - BG-I19474 Belimo learning: multiple identify commands when adding device - Device found via Address-Button after manual creation - BG-I20494 Belimo: Inherit room of device to IO's, add devices to devicestatus - BG-I21157: Belimo Add Device Dialog learned in devices not shown - BG-I20985: Belimo: fixed naming of child-IO's - BG-I21095: Belimo manual addressing: charset problem on result-message - BG2-T245: various bugfixes for belimo learning - BG-I21703 Belimo: cut and paste of Sensor sets to "not configured" - BG-I21762 Belimo Monitor: some Data contains ":" others not - Belimo Addressing: invalid device type - Belimo Addressing: device created on wrong Belimo Air/Tree - Client-Gateway - BG-I20177 RS232/RS485 Monitor on Client/Gateway not starting - Adding client to gateway: Room/Category of light group get lost - Gateway/Client: Reduced memory usage during update - Miniserver Compacts in a Gateway show an error in project analysis - Sort Client Miniservers by Name and then by switchboard - Device Status: Offline client always shown Online and with wrong Miniserver type - Gateway file distribution is interrupted by trust updates - Gateway/Client Miniservers are sorted differently in program tree and pages than in periphery tree - Gateway shows outdated project system message - BG-I21483 Gateway: Update/project not transferred to slave due to failed discovery - Gateway: Client offline message does not disappear - BG-I20934 Gateway/Client: Statistic not working for objects on a client when it previously was on the gateway - BG-I21443 Client/Gateway: Audioserver connection on a Client not working after reboot (client not authorised) - BG-I21198 Gateway/Client: Object communication commands get lost in big installations (e.g. All On of more than 128 light controllers via central light) - BG-I18466 DMX Monitor not working in Client/Gateway - Trust - Trust: User gets deleted from all members directly after it was removed from the source - To prevent accidental delete the user is now disabled for a 1 day and deleted afterwards - Trust IO cant be deleted from context menu - BG-I21014 Trust: Usergroup deletion not handled correctly - BG-I21479 Trust Member Offline Message does not disappear when nothing is subscribed anymore - BG-I20887 Trust join fails when both Miniserver have the same local address - BG-I21479 Trust Member Offline Message does not disappear when nothing is subscribed anymore - Trust transferred nfc credentials not saved - Trust has missing user group caption - Multiplicator - BG-I20962 Miniserver status not updated when opening dialog - BG-I20791 No info which Miniserver is opened - BG-I22037 Configurable controls (e.g. Window Monitor) always set to modified after cancelling control selection dialog - BG-I21827 Changes get lost when directly updating a Miniserver - BG-I21827 Error handling when transfer of files to Miniserver fails - Save backup of programChanges.xml in backup path - Auto Configuration - BG-I21298 Auto Configuration: Added Todo to configure the volume thresholds of presence sensors - BG-I21296 Auto Configuration: Create a presence detection control in thoroughfares when there is audio (Audio Player has no motion input) - Auto Configuration: No visu password per default for mode switches - Audio - BG-I19330 Audio Player: don't use decimal places for volume parameters - BG-I18904 Music Player: Input P always on when triggered via Player Group - BG-I18254 Central Audio: Send Alarm,Bell for Music Server as group events - BG-I14743 Central Audio: grouped bell off is sent if control is located on client - BG-I17237 Central Audio: grouped event is also sent to music servers - BG-I18965 Updating Audioserver-IP does not refresh configured-state of audio players - BG-I18827 Audioserver system messages displayed twice in client gateway systems - Stereo Extension: Room not displayed in periphery tree - BG-I19648 Line In ID displayed on Miniserver Compact - BG-I19330 Music Player: do not allow negative values for parameter BuzzerFav - Added volume state to audio player - Music Player: play because of presence not sent after reboot of miniserver+audioserver - BG-I21253: Audio Central: commands for Music server not executed - BG-I21442 Audio Central: Block ignores selected music server zones - BG-I21414 Music Server Zone: shown as offline in Device Status - BG-T2892 MS Compact: Internal Audioserver was not notified of planned reboot - Automatic Designer - BG-I18912 Automatic designer: Operating modes not shown when defined - BG-I18990 Automatic designer: Date-edit text cut off - BG-I17361 Automatic designer: rules with conditions using "not equal" are executing after change via app - BG-I19009 Automatic Scene: actions after wait conditions are not executed - Automatic rule: Edit dialog entries have missing text - Added Wallbox to Automatikdesigner - BG-I20843: Automatic designer: invalid maximum number of musicserver-zone-favorites - BG-I21448 Automatic Designer Dialog: fixed crash when filtering empty list - BG-I20823 Automatic Designer: Added Meter objects - BG-I19121 Automatic Designer Dialog: Controls with no actions/conditions are shown - BG-I18164 Automatic Rule: liveview not updated for new rules - Automatic Designer Dialog: rooms without valid controls are shown in room/category list - BG-I22289 Automatic Designer Dialog: config crash when using network intercommunication - Project Planning - Wallbox missing in project planning - BG-I19957 Project Planning: Multi Extension causes a second power supply & backup - BG-I20265 Fixed output in power usage sheet (project planning) - BG-I19693 Fixed addition of devices in project planning - BG-I20538 Project Planning: Invalid power used for Valve Tree - Project Planning: Moved weatherstation to outside in DEU Default file - BG-I21351 Project Planning: Nanos get an unwanted topmodule - BG-I13784 Project Planning: PWM products are combined to one dimmer even when having a different name (only installation place was used to differentiate) - BG-I21627 Project Planning: Invalid power calculation for relay extension - BG-I22583 Project Planning: Dropdown overlaps checkbox - BG-I22590 Project Planning: Negative surcharge - Device Status - BG-I19574 US/IL channels not checked on all AirBase-Types - BG-I18619 Add spinner-animation for longer requests (deviceinfo, logfile,...) - BG-I20115 Get Log File Command not working when Miniserver is configured with custom Port - BG-I20864 No device type for Extensions - BG-I20013 Updated device-info-capabilities for 1Wire, RS232, RS485 - BG-I20824 Remove sleep/wakeup commands for non-battery-devices - BG-I20710 Miniserver reboot via device status, reconnect after reboot - Device Learning - Device Learning: Data is not committed when device is replaced where setting is currently edited - Device Learning: Invalid filter set when starting search via context menu - Tree device learning: Device type column too small - BG-I20908 Air Learning: Device not found again after unpairing directly after learning it - BG-I21290 Device Learning: Identify not stopped when item is unselected - Dali Learning: - Conflicts are now resolved automatically - Searching for a lot of devices locks up config - Removed visual confirmation and load factory defaults for simplicity - Added buttons to turn on/off all lights - Search not aborted when stopping search or closing dialog - Address duplication is shown when manually editing address - Extensions not sorted - App Learning: Tree search results disappear - BG-I21056 App Air search on gateway not working properly - BG-I21749 Internorm device search results were missing correct serial number assignments - Sequence Controller - BG-I20529 Creates an if statement when it should not be needed - BG-I20386 Spaces added in between variable for TQ - BG-I17511 Set TQ Command Copying Text from Texteditor results in red line - BG-I18156 Does not correctly work with formula without space - BG-I18198 Invalid cursor position after auto-format - BG-I20780 goto-commands not adapted for undo or every line break - BG-I20838 Comments are shown as error in text editor - Goto-update not working with uppercases - BG-I21642 Crash when cancelling sequence renaming - BG-I21720 Text-output not trimmed - Stability - BG-I19414 Config crash when renaming Wallbox Gen.1 after cut/paste - BG-I19223 Config crash when saving to Miniserver - BG-I19278 Config crash when starting simulation - BG-I19359 Config crash in Media object dialog - BG-I19206 Config crash when deleting Power Supply & Backup - BG-I19192 Config crash when editing settings - BG-I19862 Config Crash Right Click Valve Actor while Virtual Input is selected - BG-I19279 Config crash when editing setting and then clicking a button - BG-I18983 Loxone Config freezes when using hostnames in a gateway project - BG-I18434 Config crash during auto configuration - BG-I20085 Config crash after paste - Multiplicator: Config crash when loading from Miniserver - Multiplicator: Config crash when loading from Miniserver - Config crash due to high communication traffic in big installations - Config crash while learning devices - BG-I19812 Config can not be closed - Miniserver reboot when tcp socket is deleted after incomplete tcp handshake - BG-I20547 Miniserver reboot when setting user attribute to empty from app - BG-I20797 Miniserver reboot when saving to large Client/Gateway installations - BG-I20886 Config crash when changing topmodule - Config crash when starting Miniserver search - BG-I20849 Lighting Controller: Config crash when deleting moods in dialog - Miniserver not restarting after crash - BG-I20850 Config crash when deleting project from overview - Gateway rebooting in rare cases when saving to Miniserver - Config crash when starting link search a second time - Config Crash when sending large encrypted webservice - BG-I19806 Config crash when opening project from project view - BG-I21417 Config crash when creating new projects - BG-I21400 Config crash when creating connection flags - BG-I21642 Sequence Controller: Crash when cancelling sequence renaming - BG-I21482 Config crash when opening config - BG-I21632 Config crash when deleting control - BG-I21630 Config crash when receiving invalid search answer - BG-I21804 Config crash when managing SD card - Fixed Debug Monitor causing ddos and memory leak on Miniserver Gen.1 by sending data to itself - Improved handling of a lot of HTTP requests - BG-I20901 possible crash when adding Enocean device via learning dialog - BG-I21948 Config crash when editing user rights - BG-I20678 High memory usage on Miniserver Gen.1 due to FTP file download resulting in possible out of memory crashes - BG-I21679 Miniserer crash with broken file - BG-I22086 Config crash when device update is reported - BG-I22180 Miniserver reboot with invalid 1-wire devices on a Multi Extension - BG-I22038 Config cant be closed after opening project planning file - BG-I22344 Config crash when opening Monitor - BG-I22506 Config crash when creating file for a gateway Miniserver - Config crash when formatting a second SD without closing dialog - BG-I22366 Config crash when editing in multi edit view - BG-I22446 Config crash after deleting device reference - BG-I22581 Config crash after insert of energy flow monitor - BG-I22480 Config crash when saving Monitor as csv - BG-I21647 Communications failure
Auch die Performance scheint optimiert zu sein. DIe Config ist tatsächlioch deulich schneller.... Bei der Android App wäre mir das lieber
Ob das aber die Versionsspruch rechtfertig lass ich mal offen.
Ist mir gerade noch beim Test der Config aufgefallen...
Prof.Mobilux
Hier ist das Performance Update...
Loxone hat wohl App und Config verwehseltZuletzt geändert von hismastersvoice; 24.03.2023, 19:25.Kein Support per PN!Kommentar
Prof.Mobilux
Ich habs mir auch gerade gedacht, das ist mal wieder typisch, so kann man sich auch aus der Affäre ziehen. Unglaublich, es wird wirklich immer schlimmer !!!!
Wer hat sich den bitte bezüglich der Config Performance beschwert ????
War aber fast zu erwarten das da Performance mäßig bei der App nichts kommen kann, ansonsten müssten sie wieder den Unterbau also das Framework ändern.
Das ist eine Klatsche ins Gesicht.
Das Update war eigentlich meine letzte Hoffnung dass ich mich getäuscht haben könnte, aber wohl eher nicht.Zuletzt geändert von Labmaster; 27.03.2023, 18:29.Kommentar
naja, wenn die aus Sicht zahlreicher Nutzer dringendsten Probleme (durch App-Update keine Steuerung des Smarthome mit bestimmten Tabletts mehr möglich) nicht gelöst werden und dann an anderer Stelle etwas (weniger dringendes) optimiert wird kann ich den Frust schon verstehen.
Man stelle sich vor ein 3 Jahre altes Auto fährt nach einem Kundendienst-Update nur noch mit Schrittgeschwindigkeit - und nach mehreren Monaten präsentiert der Hersteller dann "nur" ein Update für das Navi.... -
Johannes Bartnitzke
Mir ist halt die Hutschnur hochgegangen, weil über Monate hinweg auf ein zukünftiges Performance Update verwiesen wird und diesbezüglich wieder nichts passiert ist.
Wie soll man denn da noch reagieren ??? -
Johannes Bartnitzke
Das Problem sind in der Tat eure vollmundigen Ankündigungen, die selten das erfüllen, was ihr im Marketing versprecht. Sei es das Energy-Release, bei dem der Spot Price Optimizer ohne Visu auf den Markt geschmissen wird, oder eure strikte Weigerung einen Energiezähler in die Relay Extension einzubauen, weil ihr das lieber "per Software" löst.... oder die Audio-Revolution, die nur halb so viel kann wie der auf LMS basierte Musicserver.... Neukunden die von nix nen Plan haben glauben euch das vielleicht noch, gefrustete User eher nicht (mehr).
Es hat schon einen Grund warum in der aktuellen RC Version unendlich viel Bugfixes und nur wenig sowie kleine Neuerungen drin sind. Macht bitte weiter auf dem Weg und schmeißt nicht immer halbfertige Sachen auf den Markt.
im Moment weiß ich echt nicht ob ich mich über das eine oder andere behobene (zB Optimierungen am tree valve) freuen soll oder Angst vor der Menge an Änderungen bekommen soll .
Das könnte eine spannende Phase werdenKommentar
ja, hab gesehen dass ihr da tolle Gehäuse konstruiert habt. mechanisch gebrochen ist mir glücklicherweise noch nichts - ich hab die Gehäuse mit Schiene fixiert - die können sich nicht mehr bewegen ;-) bzw sind die Nasen nicht mehr unter Druck
Aber dennoch müsste ich die Ventile 1x pro Woche neu kalibrieren damit sie sauber schliessen - Loxone meinte im Ticket dass das Update helfen wird - ich bleib da mal positiv. -
Bogenhaus, da bist Du nicht der einzige der das angefragt hat mit dem Rekalibrieren per Logik. Das habe ich vor Jahren schon gemeldet. Anfänglich hatte ich immer das Problem das die SW meinte angeblich hängt ein Ventil (immer mal ein anderes), was aber nicht der Fall war. Zudem Neubau. Dann musste ich über die Config eine Rekalibrierung auslösen. Das hat man dann aber endlich einige Updates später in den Griff bekommen und die Meldungen sind verschwunden.
Armin Müller
Armin, es haben sehr viele Leute in diesem Forum sehr konstruktiv über alle verfügbaren Kanäle bei Loxone dafür plädiert, dass sie gehört werden. Zusammenarbeiten war immer ein grosser Wunsch. Leider war der meist sehr einseitig. Und um die Vergangenheit dann abzuschliessen: Solange Versprechen nicht eingehalten werden und die Qualität nicht stimmt, darf Loxone nicht erwarten, dass Loyalität für immer hält. Loyalität ist ein wertvolles Gut, dass auch gepflegt sein will. Und zwar mit Taten.
Mein Punkt wäre der folgende: Dein Vorstoss in Ehren und ich glaube Dir, wenn Du sagst, dass die Entwickler tun, was ihnen aufgetragen wird und sich echt reinknien.
Solange aber die Chefetage Deine Ansage "dass es keinen Grund mehr für Kritik geben wird" nicht höchstpersönlich in diesem Forum bestätigt, werden das nur sehr wenige glauben oder abwarten bis
a) die alten Versprechen endlich eingelöst sind und
b) die seid Ewigkeiten gemeldeten Bugs und Limitationen behoben sind und
c) ein schöner Teil der hunderten eingereichten Feature Requests umgesetzt wurden
Ich begrüsse die Transparenz in den Change-Logs. Ein Ansatz wäre ja auch, wenn Ihr z.B. die known Bugs und die open Feature Requests auch zeigen würdet. Dann könnten die mündigen Leute unter uns schnell beurteilen, ob die auch abgearbeitet werden (oder nicht) - oder zumindest, ob die es überhaupt bis zur Kenntnisnahme durch die Entwickler geschafft haben...
Thematisiere das doch bitte mal intern mit den Entscheidungsträgern und lass uns wissen, was dabei rausgekommen ist.Zuletzt geändert von FiCastle; 24.03.2023, 22:59.Kommentar
Finde es schon interessant und belustigend mit welcher Erwartungs- und Grundhaltung hier einige Kommentare verfasst sind.
“Neukunden ist von Loxone abzuraten“ und „Geschäftsleitung soll hier im Forum A,B und C bestätigen“
„Bespreche ABC mit dem Vorstand und gebe mir ein Feedback“
na klar random Forum Typ XYZ… die rufen sicherlich am Wochenende die GF außerplanmäßig zusammen, damit die umgehend antworten können.
Mal ehrlich..
Dazu sind einige Kritikpunkte hier voll und andere im Kern valide, einige aber komplett oder in der Art und Weise nur Käse
Mal festzuhalten ist:
Loxone läuft bei uns bereits mehrere Jahre 100% stabil, nicht ein Ausfall auf SW oder HW Ebene- Tut was es soll und steuert unser Haus inkl. Loxone fremder Themen wie: Hue, modbus Anwendungen für WP und PV, Shelly’s, Hörmann Tor und und und - unglaubliche Vielfalt an Schnittstellen und Möglichkeiten.
By the way: auf IPhone/ iPad läuft die App ganz normal und flüssig, weiter zeugen 9 Betas von sehr starken Bemühungen der Qualitätssicherung der Software…
Es tut sich also hier, zumindest scheinbar, eine Menge.
Auch wenn sich hier offensichtlich der ein oder andere persönlich auf den Schlips getreten fühlt weil „sein gewünschtes Feature“ oder die individuell hoch priorisierte Verbesserung erstmal anderen, durch Loxone wichtiger eingeschätzten zum Opfer gefallen ist: alles wird gut… und wenn man „die Schnauze so voll hat“, weil mal die Punkte in der App beim Energieflow nicht angezeigt werden, die Modbus Abfrage auf „nicht zu vertretende 5 sek. im Minimum“ und ähnliche Bugs auftreten…
Zuletzt geändert von burnatm; 24.03.2023, 23:50.Kommentar
burnatm danke für den überaus korrekten und fachmännischen Beitrag.
FiCastle Es tut mir leid das deine Anlage nicht zuverlässig läuft. Über 250.000 Projekte weltweite, wo auch mein Eigenes sowie weitere Projekte die ich persönlich betreue dazuzählen, decken sich mit deiner Aussage leider nicht.
Wenn ein Loxone Projekt anständig installiert und konfiguriert ist, gibt es keine Zweifel daran das, dass Zeug so wie du es nennst, einfach funktioniert. -
...zumindest bis zum nächsten Update?!?
Natürlich läuft das System an sich stabil, das kann ich auch bestätigen.
Trotzdem gab es auch schon öfters Einschränkungen durch ein Update, die nicht alle kurzfristig behoben wurden.
Und: es geht einfach nicht, wenn mit automatischen Updates so massive Änderungen untergeschoben werden wie
- extremer Ressourcenhunger (Tabletts sind teilweise nicht mehr nutzbar) oder
- massive Verschlechterung der Barrierefreiheit (neues kontrastarmes Design)
Da schraubt man sich mit Aufwand und einigem Invest Tablets an die Wand um dann schon ein paar Monate später feststellen zu müssen, dass man das nun wohl alle ein bis drei Jahre neu machen muss.
Da steckt baulicher Aufwand drinnen, das ist nicht nur mal ein, zwei, oder drei neue Tablets kaufen, Nein, da fängt man jedes mal wieder von vorne an mit dem Rahmen, dem mechanischen Wandeinbau, den Befestigungen, der Stromversorgung, dem Lademanagement und und und.
Gehts noch !!!
In Zeiten in denen sogar Loxone schon mal was von Nachhaltigkeit gehört haben sollte ist so ein Vorgehen ein absolutes NoGo vor allem für eine Steuerkomponente der Elektroinstallation.
(und wir sprechen bei der APP über eine reine Bedienoberfläche und nicht um Software aus dem Raketentechnik)Zuletzt geändert von Labmaster; 25.03.2023, 04:56.Kommentar
Release scheint vor der Tür zu stehen...
Prof.Mobilux
Loxone hat wohl App und Config verwehselt(Thema verfehlt, 6, setzen
). Nein, im ernst: Es werden sicherlich an Config und an App unterschiedliche Teams arbeiten. Von daher finde ich ein Bugfix-Release mit der langen Liste an Themen durchaus positiv (auch wenn ich niemals eine frische Config bei mir einsetzen würde - lernen aus Schmerz seit V8).
Ich ganz persönlich messe Loxone an 2 Versprechen, die sie hier gegeben haben, und von denen ich seit den Posts leider nichts mehr gehört habe:
1. Der Spam in der App (News, Updatemeldungen, Jobangebote) wird konfigurierbar werden: Versprochen am 17.11.2022 von Johannes Bartnitzke
Servus zusammen, Wir wollen das mächtigste Energiemanagementsystem der Welt weiter verbessern und starten deshalb die große Energie Offensive: 4 neue Produkte in den nächsten Wochen. Den Start macht die Loxone Config & App 13.1 am 19. Oktober. Hier gibt's zahlreiche neue Bausteine und Funktionen, um das Energiemanagement
2. Die App Performance wird stark verbessert. Versprochen erstmals von Florian irgendwann in 12/2021 mit der App 12.1 (nichts wurde getan), dann von Johannes Bartnitzke am 17.11.2022 und soweit ich sehe letztmalig von Florian am 21.01.2023. Seitdem sind wieder 2 MOnate vergangen ohne jegliche Verbesserung in der App.
Wir werden sehen ob Loxone seine Zusagen einhält. Ich glaube es erst wenn ich es Life auf meinen Devices sehe. Zuviel Porzellan ist da in der Vergangenheit zerbrochen. Und die 2 monatige Funkstille und die Fokusthemen in den aktuellen Alphas und Betas der App zeigen mir, dass an den Themen aktuell nicht gearbeitet wird.
MIchaelZuletzt geändert von Prof.Mobilux; 25.03.2023, 05:59.🇺🇦 Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraine
Klar ist es mehr als frustrierend das die App langsamer wurde, aber du schreibst es ja selbst seit der Ankündigung ist noch nicht einmal ein Jahr vergangen
Für mich verfehlt die Diskussion das Zeil, eine neue Config wird rausgegeben und es wird über die App diskutiert obwohl es da gar nichts neues gibt
Wenn keiner was an der Config auszusetzen hat muss die Version ja gut werden^^Kommentar
Nicht mal ein Jahr vergangen?! Seit dem Zwangsupdate ist mein Smarthome nicht mehr bedienbar. Wie lange soll ich auf einen Fix warten? 10 Jahre? Und die Performanceprobleme bestehen seit 12/2021, das ist 1,5 Jahre her.
Freut mich, wenn Du mit 12 Beiträgen anscheinend die rosarote Loxonebrille noch auf hast. Bei mir ist der Enthusiasmus und das "Geil, wieder eine geile, neue Config"-Gefühl schon lange vorbei. Irgendwann kommst Du (oder Deine Frau) einfach darauf, dass ein Smarthome auch einfach mal funktionieren muss.Zuletzt geändert von Prof.Mobilux; 25.03.2023, 09:37. -
Die Giftgrüne Brille
Denkst du wirklich für das Performanceproblem gibt es ne schnelle Lösung, das ist so wie wenn das Fundament deines Hauses erneuert werden muss
Immer bei jeden Anlass (auch wenn es z.B. was gutes ist wie jetzt ne Configversion auf Bugfixes fokusiert) gleich losmeckern halte ich aber nicht für richtig so wird der Graben nur noch größer
Ich habe auch schon 6 Jahre Loxone hinter mir, finde natürlich auch nicht alles toll und ja, dein Beitrag im Forum ist wesentlich größer und schätze ich auch sehr -
@<Andreas> Die App hat ja schonmal bestens funktioniert. Das funktionierende Fundament seines Hauses wurde niedergerissen und mit unnötigen Frameworks neu hingerotzt
Bei mir mag der Download des Release-Candidate nicht so recht. Er meint, in der ZIP-Datei befände sich ein Virus.
Miniserver V2 14 RC, 5 x Extensions, 1 x Dimmer Ext., 1 x 1Wire Ext., 1 x DMX Ext, 1 x Air Ext., 1 x Tree Ext, 1 x Modbus Ext. 1x IO Ext.
Mobotix T24, 2 x Raspberry Pi 2, Youless Energiemonitor, Loxberry,
2 x Grundfoss Magma Umwälzpumpen mit 0-10V Anschluss und Modbus.
Bartl Wärmepumpe mit TEM-Steuerung und EBUS-Protokoll. EBUS-KopplerKommentar
Des weiteren konnte ich trotz der updates bei mir noch keinen groben Fehler feststellen.
zu viel KNX und zu wenig LoxoneKommentar
Video von Loxne Config 14. https://youtu.be/Ahhz7PMQFQs
Changelog https://www.loxone.com/enen/support/changelog-config/
