Multiclick function -> one click always all lights off
  • K.Clemens
    • 92
    I'm using a multiclick block with the following functions:
    1 click: Nothing
    double click: action 1
    triple click: action 2.
    The same pushbutton is used in a lightcontroller where 1 pulse results in "light 1" on and a following pulse results in "light 1" off.
    Now I have a very strange behavior of this particular pushbutton. Whenever I double or triple click this pushbutton all lights in the house (=lightcontroller) go off.
    Is this a bug or do I have to make a marker at the 1-click function of the multiclick block and use this marker in the lightcontroller?
    • 6320
    Hi Clemens,
    Sure, you have to use always the multi click object. Otherwise the double-click or triple-click is also sent to the lights controller. The lights controller himself has functions for double and triple clicks.
    Greetings Sven
    Mal eben von unterwegs ...
    • K.Clemens
      • 92
      Thanks for the response. Indeed, I have to create a marker in the multi click object and use this marker in the light controller.
      Strange that the multiclick options for a lightcontroller can't be changed in the light controller double click options.
        • 6320
        You can set the parameter M to 0.01 or so. Double-click and Triple-click will be deactivated. But you can't use it anymore. If you only use the multi-click object you still be able to the use light controllers functions in other situations.
        It's your choice.
        • K.Clemens
          • 92
          ok, thanks for the info.
