HTTP Virtual outputs
  • Tizili
    • 15.03.2021
    • 1
    Hello, I am trying to integrate a VSSL multizone amplifier into Loxone that can be controlled via HTTP requests.
    I managed to do it in command line (curl) but I don't manage to do it in Loxone.
    Indeed, when I create a Loxone virtual output I only have the choice between the methods GET/POST/PUT/DELETE
    Or the amp API commands all work with the PATCH method.
    Sample command: PATCH /api/setplaycontrol?serial=CC909323273x&number=4&playst ate=2 HTTP/1.1\r\n\r\n
    So my question is : have you ever had success sending HTTP PATCH commands through Loxone?
    Thanks in advance and have a good week!​
