I've a ViewPlus since a year, and I'm interested in integrate it within Loxone Config. They now support an API JSON.
Here attached you can find the JSON specs.
Steps should be the following:
- Sign in to the web dashboard using your Airthings account details, 2. Go to the "Integrations" section of the main menu, 3.Select "API", 4 Select "+ Request API Client"
https://developer.airthings.com/docs...arted-consumer
I'm using OpenWeatherForecast JSON API, with the API call, which is quite straight forward to integrate. Honestly speaking, I don't know if it's possible to configure a direct-call from a Loxone Config Virtual Input.
