Daikin Emura API
  • vidor
    • 11.04.2022
    • 11
    Daikin Emura API
    Hi All,
    Finally I have found a little bit of documentation regarding the API for controlling my air conditioner.
    Unofficial api documentation and web interface to control "Daikin Emura" air conditioner - GitHub - ael-code/daikin-control: Unofficial api documentation and web interface to control &q...
    I also managed to read out the data, and I use it also as a outdoor temperature sensor.
    Now I would like to be able to control it also a little bit with Loxone, and here I would need help if possible.
    The /aircon/set_control_info has some mandatory parameters, it means that you need to include them in all the requests to this endpoint even if you are not interested in changing those specific values.
    These are the mandatory parameters:
    • pow
    • mode
    • stemp
    • shum
    • f_rate
    • f_dir
    Is there a "know how" somewhere, tutorial where I can integrate these parameters as mandatory, and rest optional. Is there a way that in the config the output parameter is "generated" ?
    Sorry if it is nonsense, but every command to be handled separately is too much I think.
    Thank you for the suggestions.
    Rgds,
    Vidor
    PS I hope this end up in German language, as I use this forum through translator.
