I have an ultrasonic sensor (UB6000-F42-U-V15 purchased from loxone) which I have recently started to integrate into my setup. Right now the readings do not match what I would expect. I am trying to determine if it is to do with my calibration or something to do with the way I have it wired in.
Would someone be able to clarify a couple of things for me?
1. How should the sensor be wired? Is it just one connection (the analogue output from the sensor -Ub) into one of the loxone analogue inputs? Or does it also need a power supply?
2. Can someone explain the sensitivity settings to me please?
In case it helps the purpose of the sensor for now is to measure the depth of water in a tank. The distance from the sensor to the floor of the tank is 1.57m. The distance from the sensor to the maximum water level in the tank when full is 0.22m. (Yes I realise this inside the unmeasurable range at start of the sensor but I am willing to accept the tank as full once it is inside this range -accuracy in this range is not important.)
I appreciate any guidance people have on wiring and/configuration of this sensor.
Thanks in advance.
Mary
