DMX and using led strips in parallel
Hi, i have the classic (not tree or air) DMX extension with DMX rgbw dimmer. I have a setup where i need to control four 24V white led strips simultanuously. Meaning they poweron/poweroff all at the same time and receive the same current (so they all produce the same amount of light). In practice (without loxone setup) this would mean they are connected in parallel to the power supply. The documentation of the dmx rgbw dimmer mentions you can bridge outputs. Does this mean i can wire my four led strips to for example the + and r channel of the dimmer? Which would leave me the other channels to do the same (for additional led strips). I noticed there is no limit mentioned in the documentation on the amount of current the dimmer can handle. My four led strips currently draw 2,7 A.Stichworte: - -
I don't know, what DMX Dimmer you are using, but - if nowhere is documented the maximum A or W per channel, then you better don't use it at all.
Bridging means, to connect the RGB(W) outputs of the dimmer to get the available power per channel multiplied by the number of outputs.
This is the opposite of your plan, to connect multiple strips to one channel.
As long as you do not overload the channel, you can run the strips in parallel.
Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraine -
Just connect two ledstrips parallel to one channel of the driver. The other two the same. So, you just use two channels and have still two channels free.
Verstuurd vanaf mijn SM-G935F met Tapatalk
Hello, pnobels! Are you tried to replace the led lamps with the new ones? From my experience, if a problem like yours appears, this is a sign that you need to replace the lamps because all the electricity system in your coach is in danger. Try to think about installing the led strip light in place of the regularly led lamps inside. It can be a better idea since the led strip light is easy to install and replace if something goes wrong. If you need help with installing the strips, let me know. I will be glad to help.Zuletzt geändert von Gast; 28.03.2022, 20:09.Kommentar
