But I can't find if this has been enabled or not. My experience of when things are supposed to be on by default is often they are not, so would like to check.
Loxone Air setting as Router
I must be missing something. In the documentation for the RGBW 24V Dimmer Air it says "All Air devices that have a permanent power supply (not battery powered) can also be used as a router. This means that signals from devices with a poor connection to the Air Base Extension are amplified and therefore a greater range can be achieved."
Stichworte: - -
Even not possible to switch this off, ON for ever...En Gruäss us de Schwiiz
KNX seit 2005
Miniserver seit Jan. 2011Kommentar
