Run through all possible colors and intensities using a single push button
    Please also refer to my question in the German forum. What I would like to do is with a single push button run through all color combinations and intensities. Is this possible? If not, what is possible?
    The Ra parameter of the Lighting Controller and using one of the I1...I4 inputs and the corresponding RGB outputs, gives already the possibility to scroll through the basic colors (R,G,B,W) with a short push and intensities by longer push. But I would like to scroll through the full RGB color spectrum.
    Any suggestions?
    • 11233
    There’s an article here: https://www.loxwiki.eu/pages/viewpag...pageId=5046637
    (use Translate).
    The „V2“ thing is a circuit that can run smoothly through all colors.
      Hi Christian, thank you for this valuable info. I will have a close look to it.
        As I was only interested to change the color and intensity by using push buttons, I changed the schematics a little bit.
        Any comments are wellcome
          I have added some logic..with a short push, the lights will go out...
