Lights "hang" (stuck) in on-position, liveview show them as off
    Basically, I have the same problem as mentioned here:
    Hey all. I'm having a very strange issue that I can't solve. My basement lights (all connected on 1 loxone output) are software-wise configured to 2 buttons: - 1 to turn on the lights for 30 minutes (via a multifunction switch) - 1 to turn the light on permanently (until clicked again) via a lighting controller. This has
    The Liveview show it as off, but the lights are kept on...
    I have had the problem before, and I solved by rewiring the lights to another output. But alas, I am running out of free outputs...
    Can anyone help me?
  • hme0354
    • 06.07.2019
    • 1042
    your relay is sticking. If the tips are not working, you have to solder in new relays or buy a new extension.
      If relays are sticking, the reason is too high switch-on current, usually because of retrofit led lamps.
      It will re-occur again and again, therefore you need to solve the reason, eg by
      - changing the led bulbs to another making
      - put a 16A coupling relay between Loxone output and the lamp.
      - if the output is used with multiple lamps, break apart the circuit to use multiple outputs for these lamps.
      Zuletzt geändert von Christian Fenzl; 08.04.2020, 06:54.
      • Gerd Clever
        • 24.07.2016
        • 642
        Last year I had exactly the same problem, always ON or always OFF. First I put a 16A coupling relay, no effect. Now I assume, it is a seldom remanence ERROR, maybe a corrupt remanence-file. In my case it worked to deactivate (temporary) the remanence of the Lighting Controller.
        Zuletzt geändert von Gerd Clever; 08.04.2020, 10:58.
          Ok thanks for the info.
          I have 8 lights (spots) on the output. Might be too much? Gonna check this weekend...
          Its been Some time... how can I deactivate the remanence?
          Kind regards
          • Gerd Clever
            • 24.07.2016
            • 642
            Lighting Controller (old): Set parameter R
            or
            Lighting Controller (new): Set parameter Rem
            Zuletzt geändert von Gerd Clever; 11.04.2020, 15:55. Grund: differentiation old/new
