Swimming Pool and Loxon
    Hello,
    does anyone have set something with Loxome to measure Ph, redox and water temp of a swimming pool ?
    and how ? Via Enocean, Knx ?
    any detail is highly appreciated as I am considering this solution for my new house but measurement of the quality of the water is a must
    thanks
    this would work with Loxone ?
      • 11238
      pH4.00……………………………………………………………….58,74mv/pH
      I’m not really sure, what the pH4.00 in front means.
      With 58,74 mV per pH, an AI (analog input) could be very unsharp.
      AI has 8 bit resolution from 0-10V, so 39mV per bit (10V/256).
      It possibly is working quite better with a 1-Wire DS2438 that has a resolution of 10 bit, that is 10mV per bit.
      But, this are only assumptions from the numbers, as I don’t understand all the French text in the spec document.
