I see many skilled Loxone users are using Hörmann UAP1 (Universaladapterplatine/Universal Adapter Print). I do *not* use Loxone, but hope for you kindness to help me anyway. (If this is still the wrong forum, may you know a better Hörmann forum?)
I have Supramatic E2 garage opener running well for 15 years.
Now I have bought a new UAP1. The plan is to have up/down pushbutton inside the house. The pushbuttons also have 2x LEDs that shall indicate open/closed state.(*)
My Installation Process:
1. Assembled the UAP1.
2. Connected the UAP1 to the Supramatic "bus".
3. Opened/closed the garage on the Supramatic buttons. All 3 relays (and on-print LEDs) worked as expected.
4. Disconnect the UAP1 - Now the Supramatic does not work - gives error "6."
5. Reconnect the UAP1 - it works again(!). And so on...
So the issue is: The Supramatic now ONLY works when UAP1 is connected. (Not a good situation because if the UAP1 lose power, is later uninstalled etc. the garage can't be opened.)
My Tests:
Error "6." in the manual means "Closed circuit - Close wicket door." (I don't have a wicket door or other safety equipment.)
On the Supramatic the "X30" socket always had a jumper installed - OK.
On the UAP1 the pins 12+13 has a jumper from factory - OK.
I have tried to 1) remove power from Supramatic, 2) remove/insert X30 jumper, 3) remove insert 12+13 jumper.
Question:
Has anyone experienced this?
How will Supramatic run without UAP1?
Maybe an owner of UAP1 could kindly remove BUS and see if Supramatic still runs?
Thanks! Martin.
My setup:
Hörmann UAP1 Manual: https://www.tor7.de/media/pdf/35/8d/...-anleitung.pdf
Hörmann Supramatic E2 Manual: https://www.teknuw.com/hormann-supra...opener-manual/
LK Fuga 2-way pushbutton with 2x 24V LED indicators: https://res.cloudinary.com/evoleska/...yk-med-lys.png
*) This is a similar installation as the Hörmann IT4 contact, except that I don't setup light+lock functions.
