i have Loxone touch surface and want to place it in the shower under 8mm painted tempered glass.
Touch surface is already connected to check if the wirring was ok. I have not pealed off brown protective layer and tried to put the glass on top of touch surface but there is no reaction when touching the glass. Then tried to put metal sheet of 3 mm on top of touch surface but there was no reaction to touch either. When you try to.touch the surface without putting anything on top, then it works well.
Could it be that the touch surface through the glass will work only when protective layer will be pealed off? I am aftaid to glue them together before finding out if it going to work or not.
Thank you for information if anyone hace faced it.
