Extending Multi Extension Air
    Hi
    I have one multi extension air in a garden house and I ran out of outputs. I noticed there is no way to connect wired extension to the air extension using single radio connection. Do I have to install another multi extension air? Can I hook both to the same external antenna?
    Thanks
    Pawel
    • 11238
    Yes, and No.
      • 3655
      The easiest way is to install a second Multi Extension Air to extend your outputs.
      If you prefer a cable connection you can change your Multi Extension Air to a Miniserver v1 or v2 depends witch Miniserver you use in your main building.
      I would install the same Miniserver Version that you have in your house.
      Then you have a backup solution for your house and you can install a Relais Extension for example at your Miniserver.
      The connection between Miniserver Gateway and Client you can realise with a Power LAN connection (Fritz Powerline or other producers)
      when a CAT6 cable is not possible.
      It works great since years in my building.
        Thank you Andreas. This is a very reasonable solution to install the second miniserver. I have wifi range there. Maybe you have some advice as to a wifi client which fits nicely into a DIN rail?
        So I would need to replace my multi extension air with miniserver (I would go for gen2) or relay extension. Then to buy the missing one.
        Anyone has a spare one and wants to trade for a multi extension air?
