DALI Smooth Dimming
  • RTheys
    • 20.02.2022
    • 3
    DALI Smooth Dimming
    Hey all,
    I'm planning on using DALI in order to individually address rail-mounted spotlights on a single track. Before I go ahead and purchase my hardware, I have a question:
    When dimming via Loxone directly or via 0-10V analog signals, the dimming has a smooth curve. This behaviour is something I want to retain in the entire building as it looks better than jumping directly to the requested level.
    Is this behaviour the same when using the DALI-extension? E.g. when you switch from 10% to 100% with a scene change, do the lights adjust smoothly, or will they abruptly change dimming levels?
    br,
  • be_we
    • 27.01.2022
    • 79
    Hey,
    yes, this is possible, look here: https://www.loxone.com/enen/kb/setting-up-dali-devices/ and search for "Fade Rate"
    Regards,
    Bernhard
