lockout period after wrong passwords
  • J V
    • 367
    Hello,
    I think my miniserver locked me out after several wrong passwords (keyboard was in the wrong language over a remote desktop )...
    Any idea how long this lock-out lasts?
    Its leds are green-flashing (left) and solid amber (right); it shows no status error in the app. (I'm trying to connect with Loxone Config). I suspect it will be ok when the leds are normal again...
    Thanks
  • J V
    • 367
    Just to answer my own question: it is somewhere between 5-10 minutes. The lock-out is per IP address per user, so the same user can login from another IP address. If you log in via the web-interface, you can see whether it does not allow you to log in due to a wrong password or due to a lock-out (and it also shows in seconds when the lock-out will end).
    The led pattern persists, so that may not be connected.
