Recessed downlights
  • vgracanin
    • 29.12.2022
    • 2
    Recessed downlights
    Hi
    I am looking for affordable dimmable 24V 3000k-ish, recessed downlights. I know Voltus has Constaled but those are over the budget. Are there any other brands that you could recommend?
    Thank You.​
    • 2592
    Beside Voltus Constaleds i use Benory LED (MR16 retrofit LED Modules) together with classic MR16 Mounts from e.g. Brumberger.
    Shenzhen Benory Technology Co., Ltd. Products:LED Lighting (LED Spotlight,LED Down Light,LED Bulb,LED Panel Light,LED Strip
    • vgracanin
      vgracanin kommentierte
      That actually looks promising, thanks. Since you have them, what would be the downside compared to Constaled?
      Zuletzt geändert von vgracanin; 30.12.2022, 22:23.
  • chrisulox
    • 15.07.2022
    • 133
    Labmaster I currently use 5 TW - Benory Spots (10W) in a 9qm bath, but for me it seems the produce too less brightness. Do you have any hint?
    Benory TW - 24V 10W 2000K-6000K 60° MR16 Spot Black -Lunatone DALI DT8 CW-WW LED Dimmer 16A Din Rail - 100W /24V Powersupply from Loxone (LOX-100-24-1 Output: 24VDC 100W)
    Is there any configuration which still can be done? Or is the power supply wrong?
      • 2592
      Don''t know,
      is the DALI Dimmer configured to allow full brightness ? (i don't know this specific Dimmer, but the PWM range might be possible to be adjusted )
      I have 4 x 8W TW Spots in a 7qm bathroom, they are bright enough
      • chrisulox
        • 15.07.2022
        • 133
        Hello,
        I got these settings from Loxone:
Name: Bildschirm­foto 2025-02-05 um 09.05.44.png
Ansichten: 93
Größe: 141,3 KB
