Unable to configure iobroker with Loxone
  • Sliderem
    • 30.06.2018
    • 60
    Hello,
    I recently installed ioBroker on a Raspberry Pi 4 and with Flux Db.
    By contrary I am not able to install Loxone Adapter. I have the following error :
    HTML-Code:
    host.raspberrypi 2023-04-10 14:57:37.528 info iobroker exit 25
    host.raspberrypi 2023-04-10 14:57:36.454 error iobroker host.raspberrypi Cannot install iobroker.loxone@3.0.1: 1
    host.raspberrypi 2023-04-10 14:56:41.380 info iobroker Installing iobroker.loxone@3.0.1... (System call)
    host.raspberrypi 2023-04-10 14:56:41.377 info iobroker NPM version: 8.19.3
    host.raspberrypi 2023-04-10 14:56:34.358 info iobroker add loxone --host raspberrypi
  • Sliderem
    • 30.06.2018
    • 60
    hello, anyone with a hint for this ? Thanks
    This is my IoBroker config
    Platform: linux operating system: linux Architecture: arm CPUs: 4 Speed: 1100 MHz Model: unknown RAM: 3.7 GB System uptime: 05:29:08 Node.js: v16.19.1 time: 1681243266009 timeOffset: -60 adapters count: 471 NPM: 8.19.3 Disk size: 117.2 GB Disk free: 104.1 GB Uptime: 05:29:09 Active instances: 5 Path: /opt/iobroker/ alive:
    • Martin1234
      • 18.01.2020
      • 288
      Hi Sliderem,
      I am sorry, cannot help you with this issue. But maybe with something else.
      I tried the Loxone adapter some years ago but decided to do my integration by another way. The Loxone adapter (some years ago) was very uncomfortable because I always had to look for the object name in iobroker to use the value later in the Loxone adapter. It was also not working perfectly, so I looked for something else.
      Finally I ended with the Node Red adapter in iobroker. In Node Red there are superb Loxone nodes available. I guess it is the node-red-contrib-loxone​. Very comfortable and stable. And you still have all objects from ioBroker available to hand them over to Loxone.
      • Sliderem
        • 30.06.2018
        • 60
        Thanks for the reply Martin!
        I will have a look, I wanted this primary for the Graphana dashboards and statistics :
        Theoretically it should work but most probably it will need some more work to integrate Node Red with the DB and with Graphana.
        Anyone else using Graphana in another configuration ?Thanks
        • Martin1234
          • 18.01.2020
          • 288
          The only reason I still use iobroker is my heating system Buderus. There is a nearly perfect adapter available for it.
          For statistics and Graohana I use the Loxberry with the Stats4lox plugin.
          • Sliderem
            • 30.06.2018
            • 60
            https://wiki.loxberry.de/plugins/statistics_4_loxone
            Thanks.... I have a version 2.3 of Loxberry installed, but never tried stat4loxone, I guess I was discouraged by the fact that the majority of the tutorials are in German. I will try to translate and give it a try.
            Thanks
            • Martin1234
              Martin1234 kommentierte
              Stats4Lox is so easy to install. I have no idea about that kind of db but it simply works. Give it a try.
