Connecting & Configure flukso gas probe FLS02-F2
    How to connect and measure gas consumption, using the flukso gas probe FLS02-F2 (https://www.flukso.net/content/gas-probe)
    A small example & config would be very welcome
  • duncan
    • 313
    The probe is a simple reed switch, so you should be able to connect 1 wire to the +24v, and the other to a digital input, then use the input pulses to link to a utility meter function block, and just set the parameters for the input pulses as required.
      Picture of the settings i use, but there is no measurement - what i'll do is daily adapt the offset value but ofcourse this should be a 1 time setting.
      Zuletzt geändert von Gast; 23.09.2015, 21:09. Grund: Updated Picture - Anybody tips why it doesn't work ?
