1-wire temperature sensors unstable recently
    Hello,
    Since 3 years I have 16 temperature sensors of type DS18B20 attached to the Loxone 1-wire bus. This has worked perfectly during this whole time. Since 1 month however, occasionally Loxone stops reading the values suddenly. It can not see the sensors anymore. The solution is than to disconnect the bus and reconnect, and it works again.
    => what could be the reason this suddenly starts to give problems?
    => how to cleanly solve this?
    -I already read the article in attached link, so it says it could be a 'latch-up effect', still I wonder why now, and how to fix this?
    -Could it be soemthign else, like the Loxone software? (firmware is up to date)
    -I was thinking of wiring the bus through a relay to reset it automatically when broken, but I'd rather fix this at the source
    -If this effect is present in just 1 sensor, how to easily detect which one without having to desolder or cut them all?
    Other info: There have been no changes to this bus in the last year. I just updated to Lox8 but the problem already already happened once just before the upgrade if I remember correctly.
  • duncan
    • 313
    did you wire the 1-wire in a star configuration as suggested by loxone? if so, its the most unreliable possible way of doing so, and may be the cause of instability
    see
    Application Note 148 explains 1-Wire network topologies and details a method to calculate the limits for reliable communication with various 1-Wire masters.
    read the whole article and see if there are any of the recommendations that you can implement.
    if you are losing all the sensors, then it suggests that the 1-wire extension may be the problem, or that the error is overwhelming the whole bus - have to introduced new wireless devices or something that could be introducing interference into the whole 1-wire bus?
    assuming you are star-wired, disconnect some of the sensors at the 1-wire extension and see if the reliability of the overall system improves.
