Miniserver shutdown
    Miniserver shutdown
    After the last update of the miniserver everything stopped working and the miniserver stopped receiving new configurations. It turns out the sd has issues, so I bought a new one. I need to turn off the miniserver to install the new sd card but how can I do this? There's no visible button...
    Has anyone else experienced something similar? This feels like a massive pain. I had miniserver for just over a year. Hope I don't need to do this every year now...
  • Robert L.
    • 922
    it is GOOD that it has no "on/off" switch..
    it is NOT enough do turn off the miniserver..
    most of you digital outputs are connected to 230V..!
    turn the fuses off,
    (turn ALL your fuses off..)
    because when you insert the SD Card, it will FALL INTO the miniserver ..
    you will have to remove the housing ...
      turn the fuses off,
      Thank you for the help. What shall I do to ensure that the house doesn't come to a halt? I assume I cannot just insert a blank sd card in the miniserver otherwise once the miniserver comes up to find an empty card, it might not be too happy about it.
      Sent from my SM-G935F using Tapatalk
