ich bin auf der Suche nach einer Moeglichkeit, ein anwesendes Fahrzeug zu erkennen.
Welche Moeglichkeit, von IR-Schranke einmal abgesehen, nutzt ihr dafuer?
Thx und Gruss,
tholle
#include <ESP8266WiFi.h> #include <WiFiClient.h> #include <WiFiUdp.h> //WIFI-SSID + Password const char* ssid = "WIFI-SSID"; const char* password = "PASSWORD"; //IP + UDP-Port MiniServer IPAddress RecipientIP(192, 168, 1, 1); unsigned int RecipientPort = 7000; //Sensor 0 int sensor_0 = 1; //0 = off / 1=on short difference_val_0 = 3; //Difference (cm) to send changes to MiniServer //Sensor 1 int sensor_1 = 0; //0 = off / 1=on short difference_val_1 = 50; //Difference (cm) to send changes to MiniServer //Sensor 2 int sensor_2 = 0; //0 = off / 1=on short difference_val_2 = 50; //Difference (cm) to send changes to MiniServer //Looptime (miliseconds) int looptime = 1000; //1000ms = meassurement every second //Debug (Serial-Monitor) int DEBUG = 0; //0 = off / 1=on //no need to change WiFiUDP Udp; long duration0 = 0, distance0 = 0, duration1 = 0, distance1 = 0, duration2 = 0, distance2 = 0; long distance0_old = 0, distance1_old = 0, distance2_old = 0; long calc0 = 0, calc1 = 0, calc2 = 0; #define echoPin0 D3 // Echo Pin #define trigPin0 D2 // Trigger Pin #define echoPin1 D5 // Echo Pin #define trigPin1 D4 // Trigger Pin #define echoPin2 D7 // Echo Pin #define trigPin2 D6 // Trigger Pin void setup(void) { Serial.begin(115200); pinMode(trigPin0, OUTPUT); pinMode(echoPin0, INPUT); pinMode(trigPin1, OUTPUT); pinMode(echoPin1, INPUT); pinMode(trigPin2, OUTPUT); pinMode(echoPin2, INPUT); WiFi.begin(ssid, password); Serial.println(""); // Wait for connection while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); } Serial.println(""); Serial.print("Connected to "); Serial.println(ssid); Serial.print("IP address: "); Serial.println(WiFi.localIP()); } void loop() { /* The following trigPin/echoPin cycle is used to determine the distance of the nearest object by bouncing soundwaves off of it. */ if (sensor_0 == 1) { digitalWrite(trigPin0, LOW); } if (sensor_1 == 1) { digitalWrite(trigPin1, LOW); } if (sensor_2 == 1) { digitalWrite(trigPin2, LOW); } delayMicroseconds(2); if (sensor_0 == 1) { digitalWrite(trigPin0, HIGH); } if (sensor_1 == 1) { digitalWrite(trigPin1, HIGH); } if (sensor_2 == 1) { digitalWrite(trigPin2, HIGH); } delayMicroseconds(10); if (sensor_0 == 1) { digitalWrite(trigPin0, LOW); duration0 = pulseIn(echoPin0, HIGH); } if (sensor_1 == 1) { digitalWrite(trigPin1, LOW); duration1 = pulseIn(echoPin1, HIGH); } if (sensor_2 == 1) { digitalWrite(trigPin2, LOW); duration2 = pulseIn(echoPin2, HIGH); } //Calculate the distance (cm) distance0 = duration0 / 58.2; distance1 = duration1 / 58.2; distance2 = duration2 / 58.2; if (DEBUG == 1) { Serial.print("0: "); Serial.print(distance0); Serial.print(" / "); Serial.println(distance0_old); Serial.print("1: "); Serial.print(distance1); Serial.print(" / "); Serial.println(distance1_old); Serial.print("2: "); Serial.print(distance2); Serial.print(" / "); Serial.println(distance2_old); } //calculate difference last to new meassure calc0 = distance0_old - distance0; calc1 = distance1_old - distance1; calc2 = distance2_old - distance2; //store last result distance0_old = distance0; distance1_old = distance1; distance2_old = distance2; //write long to char char buffer[50]; snprintf(buffer, sizeof(buffer), "sensor1=%d sensor2=%d sensor3=%d", distance0, distance1, distance2); if ((abs(calc0) > difference_val_0)) { sendUDP(buffer); } if ((abs(calc1) > difference_val_1)) { sendUDP(buffer); } if ((abs(calc2) > difference_val_2)) { sendUDP(buffer); } delay(looptime); } //UDP-Befehl senden void sendUDP(String text) { Udp.beginPacket(RecipientIP, RecipientPort); Udp.print(text); Udp.endPacket(); if (DEBUG == 1) { Serial.print("UDP-Send to MiniServer: "); Serial.println(text); } delay(10); }
