EAP Modul 2020 TCP/IP
  • HIS-Loxone
    • 551
    Hat schon jemand von euch das Modul 2020 von EAP in betrieb?
    Ich habe das Problem das ich auf dem zusatzmodul e16x1 die KTY81/210 Fühler nicht in die Loxone Config bekomme.
  • HIS-Loxone
    • 551
    Hier der Auszug der Config
    b02 system, 1 extensions, 06.03.2018, 11:07
    SlaveAdr=255 b02: HW=2600, SW=36
    HR30 = 0     = 0x0000 = 0000000000000000b         //timeout [0,1sec]
    HR31 = 4660  = 0x1234 = 0001001000110100b         //config enabled, not permanent
    HR32 = 4660  = 0x1234 = 0001001000110100b         //default enabled, not permanent
    HR33 = 0     = 0x0000 = 0000000000000000b         //monoflop timeout [0,1sec]
    IR2  = 0     = 0x0000 = 0000000000000000b         //digin
    e16xi: HW=30, SW=1
    HR136 = 11    = 0x000B = 0000000000001011b        //XC1: KTY81/210
    HR137 = 11    = 0x000B = 0000000000001011b        //XC2: KTY81/210
    HR138 = 11    = 0x000B = 0000000000001011b        //XC3: KTY81/210
    HR139 = 11    = 0x000B = 0000000000001011b        //XC4: KTY81/210
    HR140 = 11    = 0x000B = 0000000000001011b        //XC5: KTY81/210
    HR141 = 11    = 0x000B = 0000000000001011b        //XC6: KTY81/210
    HR142 = 11    = 0x000B = 0000000000001011b        //XC7: KTY81/210
    HR143 = 11    = 0x000B = 0000000000001011b        //XC8: KTY81/210
    HR144 = 11    = 0x000B = 0000000000001011b        //XC9: KTY81/210
    HR145 = 11    = 0x000B = 0000000000001011b        //XC10: KTY81/210
    HR146 = 11    = 0x000B = 0000000000001011b        //XC11: KTY81/210
    HR147 = 11    = 0x000B = 0000000000001011b        //XC12: KTY81/210
    HR148 = 11    = 0x000B = 0000000000001011b        //XC13: KTY81/210
    HR149 = 11    = 0x000B = 0000000000001011b        //XC14: KTY81/210
    HR150 = 11    = 0x000B = 0000000000001011b        //XC15: KTY81/210
    HR151 = 11    = 0x000B = 0000000000001011b        //XC16: KTY81/210
    IR104 = 518   = 0x0206 = 0000001000000110b        //In 1: KTY81/210 0..65535 [dig in counter value]
    IR105 = 324   = 0x0144 = 0000000101000100b        //In 2: KTY81/210 0..65535 [dig in counter value]
    IR106 = 334   = 0x014E = 0000000101001110b        //In 3: KTY81/210 0..65535 [dig in counter value]
    IR107 = 599   = 0x0257 = 0000001001010111b        //In 4: KTY81/210 0..65535 [dig in counter value]
    IR108 = 1500  = 0x05DC = 0000010111011100b        //In 5: KTY81/210 0..65535 [dig in counter value]
    IR109 = 1500  = 0x05DC = 0000010111011100b        //In 6: KTY81/210 0..65535 [dig in counter value]
    IR110 = 1500  = 0x05DC = 0000010111011100b        //In 7: KTY81/210 0..65535 [dig in counter value]
    IR111 = 33    = 0x0021 = 0000000000100001b        //In 8: KTY81/210 0..65535 [dig in counter value]
    IR112 = 1500  = 0x05DC = 0000010111011100b        //In 9: KTY81/210 0..65535 [dig in counter value]
    IR113 = 1500  = 0x05DC = 0000010111011100b        //In 10: KTY81/210 0..65535 [dig in counter value]
    IR114 = 1500  = 0x05DC = 0000010111011100b        //In 11: KTY81/210 0..65535 [dig in counter value]
    IR115 = 1500  = 0x05DC = 0000010111011100b        //In 12: KTY81/210 0..65535 [dig in counter value]
    IR116 = 1500  = 0x05DC = 0000010111011100b        //In 13: KTY81/210 0..65535 [dig in counter value]
    IR117 = 1500  = 0x05DC = 0000010111011100b        //In 14: KTY81/210 0..65535 [dig in counter value]
    IR118 = 1500  = 0x05DC = 0000010111011100b        //In 15: KTY81/210 0..65535 [dig in counter value]
    IR119 = 1500  = 0x05DC = 0000010111011100b        //In 16: KTY81/210 0..65535 [dig in counter value]
    Zuletzt geändert von HIS-Loxone; 06.03.2018, 10:33.
    • Gerhard
      Gerhard kommentierte
      Kannst du mir das etwas näher erklären was ich da in der Loxone Config einstellen muss. Ich habe im Moment nur ein B01 Modul mit 8DI.. Ich hab Baudrate und parity eingestellt, an der Lox extention und am Modul terminiert....wo ich die richtigen Register einstelle ist mir noch schleierhaft. Bis jetzt habe ich noch keine Werte empfangen.
    • Gerhard
      Ich habe übersehen das ihr hier ja TCP Modelle verwendet und ich ein RTU Modell aber da kannst du mir eventuell ja auch weiterhelfen.
  • HIS-Loxone
    • 551
    So jetzt hab ich es gefunden
    dachte immer das HRXXX meine Ausgänge sind die Ausgänge fangen aber mi IRXXX an
    • eisenkarl
      • 1350
      Hallo, gibt es irgendwo eine genauere Beschreibung, wie man das EAP System mit Loxone verwendet?
      Auf der Webseite von EAP finde ich leider keine Doku...
