Shelly
  • Opet
    • 09.05.2020
    • 22
    #451
    Ja habe ich gemacht gleich wie bei den Farben.
      • 4323
      #452
      Mach die Shelly mal stromlos und versuche die Befehle im Browser abzusetzen damit du auf den Fehler kommst!
      In der Regel verschluckt sich die Bulb wenn man Parameter schickt die außerhalt ihrer Möglichkeiten sind.
      Bin mir sicher wenn du in die Fehlersuche etwas Zeit investierst kommst du auf den Fehler.
      Liveview, Browserbefehle, Shelly App usw. sind deine Freunde!
      https://shelly-api-docs.shelly.cloud...amily-overview
      • ager
        • 15.11.2017
        • 48
        #453
        Hello Guys, Sorry for english
        I have read almost all regarding shelly bulb here. Many thanks for help especially to AlexAn
        I have tried to implement bulbs to Loxone based on loxwiki templates and all is working but to be honest is so much confusing I suppose.
        To Opet
        He wrote: If I tap the light bulb (light control) in the lox app and want to change something, nothing works anymore.
        It was also me case and it confuse me. If I understand to Opet well he means if he change in loxone app for example color of bulb of course nothing works becasue Light controller output AQs is connected to switch (Schalter) and if you change color of bulb in any scene manually in loxone app output AQs =-1 and it means switch is off so thats why bulbs do nothing,
        I am aware that it is only suggestion config from AlexAn and each one can do it any way. But to avoid any confusion It should be so nice if anybody can share final config for bulb and RGBW2 where you can control from loxone app as it is Loxone device (mean no additional outputs in loxone light controller as schalter, Helligkeit and Weis dimmer...)
        to Gast
        In this threat on page 26 he wrote how he did it and I have also tried (see picture below) same and looks like it is working well (except some small issues) but I am sure you have already final working config.
Name: 01 forum.jpg
Ansichten: 1298
Größe: 42,7 KB
        So can somebody post final working config for Shelly Bulb and RGBW2 dimmer to be able to controll them from loxone app as it is original loxone device please?
        Many thanks for help.
        • MGoth
          MGoth kommentierte
          Do You have meanwhile the correct configurazion and could share it?
        • 4323
        #454
        Ehrlich gesagt ist die Leuchtkraft der Bulb ziemlich schwach und ich möchte da keine Energie mehr reinstecken.
        Lösung für den Schalter hab ich einfach so umgesetzt in dem ich die aktuelle Szene den Schalter aktivieren lasse wie im Wiki:
        Klicke auf die Grafik für eine vergrößerte Ansicht  Name: Bulb.PNG Ansichten: 0 Größe: 50,7 KB ID: 248968
        Die RGBW2 wird eine neue Firmware bekommen und dann muss man schauen wie man das am einfachsten getrennt in Farbe und Weiß umsetzen kann.
        Zuletzt geändert von AlexAn; 11.05.2020, 15:05.
        • MGoth
          MGoth kommentierte
          Guten Morgen!
          gibts hierzu schon etwas Neues?
          Ich habe nun einen RGBW2 und wollte den einbinden. Kann ich dafür Deine Vorlage für die Bukb nehmen?
          Wo finde ich die Befehle für die Virtuellen Ausgänge? Die Vorlage von der LoxWiki enthält ja nur die Befehle für RGBW2 im Single Mode, wenn ich das richtig sehe.
          Vielen Dank!
          Nein noch nicht aber probier einfach mal die Bulb Vorlage!
          Firmware hab ich mir noch nicht angeschaut mit der Trennung.
        • MGoth
          MGoth kommentierte
          Was bedeutet das kalt & warmweiß in der Konfig?
          Ich habe an den RGBW2 eine RGB+W Stribe angeschlossen. Dh. eigentlich will ich das genau so steuern können.
          Dh. einmal die RGB-Lichtszene einstellen (Farbe und Gain) und dann noch das weiß Dimmen (gain).
      • deepinpowder
        • 07.03.2016
        • 412
        #455
        Zu den Shelly Bulbs. Ich kann nur die Yeelight empfehlen. 1000 mal besser als die Shelly Bulb
          • 4323
          #456
          Shelly hat jetzt ein Duo GU10 Leuchtmittel zum Dimmen und verstellbar im Farbton: https://www.shelly-support.eu/lexiko...elly-duo-gu10/
          Die Duo E27 ist schon länger verfügbar und ebenfalls dimmbar und verstellbar im Farbton: https://www.shelly-support.eu/lexiko...69-shelly-duo/
          Preis jeweils ca. 11Euro
          Anfang Juni kommen dann noch 4 neue Geräte
          Zuletzt geändert von AlexAn; 16.05.2020, 12:15.
          • deepinpowder
            • 07.03.2016
            • 412
            #457
            Achtung zu den GU 10. Die haben nicht die "perfect fit" Form wie die GU10 der HUE mit 54 mm. Die Länge entspricht den alten HUE GU10 von ca 75 mm . Die Dinger sind sehr lang.
              • 6318
              #458
              Ich habe im Außenbereich noch eine Intertechno 433Mhz 3-fach Aktor. Diesen hätte ich gern wegen der Statusrückmeldung ersetzt. Leider hat aber der Shelly2 keine 16A Relais verbaut. Ich weiß noch nicht ob der Platz reichen würde, aber kann man auch 2 Shelly1 direkt nebeneinander betreiben? Bei den Funksachen stand sonst ja immer dabei, dass die einen Mindestabstand zueinander einhalten sollten. Oder habe ich einen Shelly übersehen, der 2-3 Kontakte hat die 16A können?
              • alex68
                alex68 kommentierte
                ich habe dafür einen "hager-contacteur Endschalldämpfer ESC425S 25A 4NA 230 V" in Verwendung - wird für das Schalten einer 400V Pumpe verwendet
              • 11237
              #459
              Bei Wifi denke ich nicht, dass du Abstandsprobleme bekommst.
              Nur der 1er hat 16A. Die UL-Version des 1er hat bessere Panasonic-Relais (weniger anfällig fürs Verkleben).
                Okay
            • Bullit
              • 25.10.2018
              • 549
              #460
              Hey Svethi, ich betreibe 2 Shelly 1 im dichten Abstand (1-2cm) nebeneinander hinter einer Steckdose und hinter einem Lichtschalter. Absolut keine Probleme damit. Funktionieren seit Monaten absolut tadellos.
              Gehe also mit Christian mit und denke, dass das auch bei dir keine Probleme verursachen wird.
                • 4323
                #461
                Je nach Leistung kann die Abwärme ein Thema werden da die Dinger ganz schön warm werden!
                • Bullit
                  • 25.10.2018
                  • 549
                  #462
                  Also in meinem Falle war es noch kein Problem. Sind handwarm im geschalteten Zustand über Stunden hinweg. In meinem Anwendungszweck laufen die aber maximal so lange wie ein Tag läuft. Bei mir wird beim Schlafen/Abwesenheit die Küche bzw ihre Steckdosen stromlos geschalten. Wie es bei tagelangem Einsatz ist kann ich somit nicht abschliessend sagen.
                    • 6318
                    #463
                    Also die Dinger sind für den Garten. Und werden nicht ständig geschaltet. Zu meist hängen da auch nur geringe Lasten dran. Da es sich aber um Steckdosen handelt, würde ich die lieber mit 16A Relais betreiben um auch mal den Häcksler anstecken zu können. In dem Fall würde ja sogar stromlos geschaltet und die Betriebszeit ist auch begrenzt. Wäre also eher zu vernachlässigen.
                    • Bullit
                      • 25.10.2018
                      • 549
                      #464
                      Denke da wird das absolut überhaupt kein Problem sein. Auch bei langen Schaltzeiten war bei mir die thermische Geschichte nie ein Problem. Kann die Shellys eigentlich wirklich nur empfehlen. Sind halt WLAN-Dinger. Aber dafür sind die Dinger wirklich top und sind zuverlässig.
                        • 4323
                        #465
                        Aktuell hat Shelly Qualitätsprobleme bei der Shelly Door/Window und ich würde mit einem Kauf aktuell abwarten!
