Shelly
  • deepinpowder
    • 07.03.2016
    • 412
    #781
    3EM : https://shop.shelly.cloud/shelly-3em...ome-automation
    Einfach ein Foto des FI + der umliegenden Sicherungen zeigen, dann helfen hier alle und Du kannst bestellen und dein Elektriker einbauen....
    • querex
      • 14.07.2020
      • 177
      #782
      Going to continue on the Shelly EM.
      For an electric 3 phase + N cooktop, is it possible to use the Shelly EM with only 1 clamp, to detect cooktop usage?
      The cooktop pits are always connected between a phase and N (230v).
      So I was thinking, instead of connect 3 clamps arround each phase, it should be sufficient to only measure the N (common wire) return?
      But I don't know if the Shelly EM + 1 clamp could provide me the N current flow instead of a phase current flow...
      Many thanks.
        • 3263
        #783
        This will not work due to the phase shift of 120°!!
        in the hurry i only found a german video in wich the case will be explained
        Heute werden wir im Neutralleiter den Strom messen. Wir messen ob bei de Aufteilung von Drehstrom eine Überlastung vorliegt. Strom messen im Neutralleiter. →...
        L 1 2,9A, L2 4,3A, L3 1,25A. = in sum 8,45A
        would you measure only the current on N = 3.1A => this is not the sum!! this ist "something" due to phase shift.
        "Extreme case" - motor, the loads a completely symmetric. => The current in N = 0, there is no need of an N.
        you need a three phase meter!
        Klicke auf die Grafik für eine vergrößerte Ansicht  Name: image.png Ansichten: 0 Größe: 964,3 KB ID: 368840
        Zuletzt geändert von Thomas M.; 29.11.2022, 08:21.
          Thomas M. kommentierte
          another "wisdoms"
          The maximum current in the N conductor must be less than the sum of the three currents from the 230V~ conductors, because the "current peaks" are delayed.
          and
          The current in the N conductor can never be greater than the maximum current of *the largest* consumer.
        • querex
          querex kommentierte
          Indeed :/ when 3 identical loads are connected between the 3 phases and N.
          No current is flowing trough N.
          I did forget even that
          Thanks for the reply!
        • 4323
        #784
        Das neue Shelly Plus Addon für die Plus Serie ist heute vorgestellt worden.
        Preis: etwas über 16Euro inkl.
        Shelly Plus Add-on
        analoger 0-10V Eingang
        digitaler Eingang
        Sensoren:
        • Up to 5 DS18B20
        • Single DHT22
        • NTC resistors with 10 kΩ nominal resistance and β=4000 K
        • Photoresistors
        • PIR sensors
        • Soil moisture sensors
        • Ultrasonic proximity sensors
        • Capacitive liquid level sensors
        • Sound detectors
        • Other analog sensors with 0 to 10 V output voltage
        Mit dem analogen Ausgang ist es leider nichts geworden.
        So wie es aussieht wurden die 3x3 Klemmen ausgeführt um die max. 5x1Wire leichter anklemmen zu können.
        • oa20
          oa20 kommentierte
          Hallo, kann der Shelly Plus Addon bei dem DS18B20 das gesamte Temperaturspektrum abbilden (-55 bis 125°C) ? Danke. Sg
          Hab ich nicht getestet aber das sollte schon passen
        • 4323
        #785
        Anbindung Addon der Plus Serie ist im Wiki
        Shelly Plus Addon - LoxWiki - LoxWiki (atlassian.net)
        Templates für UDP: Shelly Plus per UDP - LoxWiki - LoxWiki (atlassian.net)​​
        Beschreibung: Shelly Plus Add-on
        Klicke auf die Grafik für eine vergrößerte Ansicht  Name: image.png Ansichten: 0 Größe: 16,9 KB ID: 373462
        Klicke auf die Grafik für eine vergrößerte Ansicht  Name: image.png Ansichten: 0 Größe: 399,9 KB ID: 373463Klicke auf die Grafik für eine vergrößerte Ansicht  Name: image.png Ansichten: 0 Größe: 424,5 KB ID: 373464Klicke auf die Grafik für eine vergrößerte Ansicht  Name: image.png Ansichten: 0 Größe: 389,3 KB ID: 373465
Ansichten: 1221
Größe: 171,3 KB
        Die Aktualisierung des Analogen Eingangs klappt noch nicht so ganz aber ich denke das wird schon...​​​​
        Zuletzt geändert von AlexAn; 03.01.2023, 17:15.
          • 4323
          #786
          Neue Geräte sind im Anmarsch:
          All Product - Products - Shelly
          Shelly Pro 3EM
          Modbus TCP Register und API für eine Saldierung sind noch nicht vorbereitet - also warten mit der Bestellung​
          kein eingebautes Relais aber ein Relais Addon für die Pro Serie ist in Vorbereitung
          Shelly Plus Smoke Alarm - All Product - Products - Shelly
          leider wieder die CR123A und eine Laufzeit von 1-2 Jahren​
          Zertifizierung unklar
          Shelly Plus Plug S
          Zuletzt geändert von AlexAn; 07.01.2023, 09:57.
            • 4323
            #787
            Event vom 6.1.2023
            https://www.youtube.com/live/b0KzFOfevwo?feature=share
            ab Februar 2023
            Shelly Blue Button
            Bluetooth Taster für die Hosentasche über ein Bluetooth Gateway z.B. eine Shelly Plus Plug oder Shelly Wall Display
            neue App
            ab März 2023
            Shelly Wall Display
            4Zoll Touch
            ohne N für die UP Dose
            1Relais 10A
            Temperatur, Feuchtigkeit und Lux Sensor
            Bluetooth Gateway
            ab 2.Halbjahr 2023
            Matter für die Generation 2 also Plus und Pro Serie
            Shelly hat Qubino gekauft (Hersteller für Z-Wave Geräte)
            Zuletzt geändert von AlexAn; 07.01.2023, 18:44.
              • 4323
              #788
              Pro3EM per Modbus TCP Zwischenstand:
              EnergyMeter OK
              Klicke auf die Grafik für eine vergrößerte Ansicht  Name: image.png Ansichten: 0 Größe: 32,8 KB ID: 375858
              EMData (Energiewerte) zur Zeit noch unbrauchbar - Firmware 0.12.1
              keine Saldierung der Leistung und Energiewerte
              Wiki Eintrag:
              Shelly Pro per Modbus TCP - LoxWiki - LoxWiki (atlassian.net)
              Zuletzt geändert von AlexAn; 16.01.2023, 16:17.
                Korrekt
                Lightpicture kommentierte
                Zufrieden mit dem Teil?
                Hast die Stromzangen gleich nach dem FI eingebunden?
                Grundsätzlich ja bis auf die fehlende Saldierung und die fehlende Werte.
                Doku muss ich noch aktualisieren bzw. nachsehen was zwischenzeitlich gefixt wurde. Aktuell würde ich die UDP Variante einsetzen.
                Ja nach dem FI aber das ist egal solange der richtige Strom erfasst wird. Einbaurichtung/Bezeichnung ist ein Chaos bei Allterco und man muss selber die Anlage kontrollieren egal was da aufgedruckt ist.
                Das BT Gateway wird noch spannend werden
                Zuletzt geändert von AlexAn; 03.04.2023, 14:05.
            • Toms84
              • 13.09.2015
              • 161
              #789
              Servus.
              Hat von euch schon jemand einen Shelly Plus H&T
              über Mqtt eingebunden?
              Ich hätte es gestern versucht.Es kommen keine Daten.
              Vermutlich liegt es an Shelly.
              Deshalb hätte mich interessiert ob es schon bei jemanden erfolgreich läuft?
              • Klartext
                • 426
                #790
                Läuft bei mir ohne Probleme, im Wiki war eine Anleitung
                (Batterie hält aber nicht besonders lang...)
                • Toms84
                  Toms84 kommentierte
                  Danke.Habe ich voll übersehen.
                  Ja die Batterie hat es mir gestern bei den Tests schon leer gesaugt 😬
              • jadi84
                • 07.01.2019
                • 107
                #791
                Nutze den Standard HT und läuft bei mir wie im Wiki beschrieben.
                • Eusebius
                  • 08.09.2017
                  • 60
                  #792
                  Bei meinem Shelly Plug S mit neuester Firmware v1.12.2 gibts unter settings/internet keine developer options -> kein coIoT -> kein udp?
                    Per IP im Browser nicht in der App!
                    Zuletzt geändert von AlexAn; 12.02.2023, 20:59.
                • Zimzima83
                  • 17.02.2020
                  • 7
                  #793
                  Hallo Zusammen
                  Hat bis Dato jemand Erfahrung mit dem Shelly Pro 3 LAN und WiFi-DIN-Rail Switch?
                  Lässt sich dieser mit den bereits vorhanden Templates oder Beschrieben in Loxone integrieren?
                  Danke für eure Rückmeldung.​
                    Hab selber keine 3er aber versuch mal die Pro4PM und lösch den Rest.
                • <Andreas>
                  • 07.03.2023
                  • 290
                  #794
                  Hallo brauche mal einen Anstoß
                  Ich habe einen Shelly Plus1PM über MQTT angebunden
                  - Ich lese die Leitung in W aus und wenn ich von den Gerät den Stecker ziehe bleibt natürlich der letzte Wert erhalten, wie könnte ich das regeln, evtl. MQTT last will?
                  - Der Stromzähler in Wh fängt nach jeder Unterbrechung wieder von 0 an, wie könnte ich das am elegantesten den Loxone Zählerbaustein beibringen?
                    • 4323
                    #795
                    Bei den Shellies bleibt nur bei den EMs der Zählerstand erhalten!
                    Nur die Leistung an den Verbrauchszähler dann macht er sich die Energie selber dazu.
                    Ein Tipp am Rande: die Shellies vertragen häufiges stromlos schalten nicht
