Viel lieber würde ich aber die relevanten Daten von der Heizung an LOXONE (Vorlauftemperatur etc.) und natürlich auch andersrum (Verlauftemp. verändern) austauschen.
Sorry for writing in English. But you should look at Bosch knx 10 gateway to integrate in Loxone. But I doubt you can do more then you're able to do with the MBLan....
I have a Junkers heater with Heatronic 3 and FW200 (the GC9000 has the newer EMS2) and worked out a solution with Raspberry Pi and MQTT integrated into Loxone (Heatronic 3 is not compatible with the KNX gateway).
The Raspberry Pi solution is also possible for your Junkers heater, but it's a bit more difficult then using the KNX10 gateway I suppose.
But the control using the raspberry Pi is also limited (same as the MBLan).
If someone is interested I can make a howto.
Many thanks for your effort. Of course, there is interest, otherwise I would not have opened this treat. :-) I think that there are certainly more people who deal with this.
I'll expand the docu as soon as possible, but it's not "einer relativ einfachen losung".
When you own the newer CW or CR controllers, the KNX solution is the most easy.
