Would it be possible to run through RGB colors and light intensity, by using a single push-button? When looking into the parameters of the lightcontroller V2 there is an input parameter Ra. It says that a short push with run you through the basic RGB colors and a long push will change the intensity. However it seems not to work at all. If a single push button cannot be used, how can i get this scenario working?
Probably I overlooked something and it has something to do with Smart Actor.
Any suggestion please?
