Color selection and dimming with the push of a button
    I would like to use following scenario: by pushing a button, i can fluently change the colors (RGB) of my ledstrip. Using same or another button I can change the light-intensity fluently.
    Would it be possible to run through RGB colors and light intensity, by using a single push-button? When looking into the parameters of the lightcontroller V2 there is an input parameter Ra. It says that a short push with run you through the basic RGB colors and a long push will change the intensity. However it seems not to work at all. If a single push button cannot be used, how can i get this scenario working?
    Probably I overlooked something and it has something to do with Smart Actor.
    Any suggestion please?
    • 5161
    Da Du hier im deutschen Forum bist, antworte ich mal auf Deutsch
    Ra auf 1, Taster auf einen der Eingänge I1 bis I4
Ansichten: 264
Größe: 63,4 KB
    lg Romildo
      Thanks for your answer and sorry to post my mail in German forum. I was indeed able to get this working. But is there any means to scroll to all possible colors instead of only R, G and B?
