Leakage Detection winth loxone
    Hi ,
    I have been asked to install water leakage automation system, which detects if there is a leakage.
    I thought about installing many sensors but this is not the solution the client wants.
    the building is 8000 Sqm, Each floor has 1000 sqm and is devided to 4 parts. each unit has water metering system- Total 4 metering system. the size of the tubes are 1 1/2 " or 2 " .
    I was thinking to start by finding a good water flow meter 0-10v by measuring any dramatic change. Does anyone have any better ideas ?
    Thanks in Advance
    Zuletzt geändert von Gast; 22.11.2020, 13:20.
  • Miep Miep
    • 18.01.2017
    • 520
    That‘s the way commercial Systems work. You just need to find out what exactly dramatic change is.
    Zuletzt geändert von Miep Miep; 22.11.2020, 14:53.
      I did not understand , what do u mean?
      • Miep Miep
        Miep Miep kommentierte
        Sorry, I changed my comment but somehow it didn‘t make it back.
      Dramatic is something I can count , if x> ...
      but what is the best and accurate way to measure it ?
      • alex68
        • 09.02.2019
        • 42
        your client should define what he understands by a "leakage" - because it goes from detecting that a toilet has a flush that doesn't close perfectly to a broken pipe
          ok, thats understood . but are there any specific 1 1/2 water metering that are recomanded ?
            • 11238
            You don’t need 0-10V for water flow, but simple pulses for each xxx liters.
            Detection logic would be somewhat of, “If impulses do not stop even after hours, there is some kind of leaking”.
            • cdrescher
              • 152
              It also depends on the building. If this e.g. a school and you want to detect vandalism at toilets I still recommend a leackage detector.
                Thanks 🙏
                  Thank you, too. I think your ideas helped me to find a way, how to resolve a challenge "security" in smart homes. Do you have further suggestions?
