I am new to this forum so thank you for your support.
I have an "old (20years)" installation of HAGER TEBIS- made of controller + 10 actuators (TS200) and 25 pushbuttons (TS304) devices.
After 20 years I do have more and more of the TS200 failing (power or contacts not working as expected any longer) so I though the Loxone was a good replacement. I now have a miniserver and relay module.
I can easily programme a push button from the Loxone KNX interface to sent KNX packets to the EIB relays (TS200) but I can't manage to use a pushbutton from knx to send a packet to the loxone (to activate a lamp/realy in Loxone) by example.
My question is the following : can the Loxberry be used to track packets from from the EIB bus end send them as actions to the Loxone miniserver ?
If yes, do any of you can help me with the basic programming of this in the Loxberry.
Thanks a lot for your help and any additional question if my explanation is not clear.
Regards
Luc
