EtherCAT connection to Loxone?
    Hello,
    I want to connect "servo-driver" to Loxone via EtherCAT communication bus.
    How it can be connected and does Loxone support such a communication protocol or any gateway for that?
    Thanks much.
    • 11238
    Just googling around, I‘ve found two possible options to connect to Loxone:
    EtherCat to MQTT interface (+LoxBerry with MQTT Gateway)
    EtherCat to Modbus TCP Interface (Modbus TCP is natively supported by Loxone, LIMITED Poll time!)
    Der Buskoppler EK9000 verbindet Ethernet-Netzwerke mit den EtherCAT-Klemmen (ELxxxx) sowie EtherCAT-Box-Modulen (EPxxxx) und setzt die Telegramme von Ethernet...
    • hme0354
      • 06.07.2019
      • 970
      It also depends in the Servo Drive. For some Drives you need a NC libary.
        Then is better to choose Servo Driver supporting Modbus RTU RS485 protocol for controlling, maybe more safer for set up.
      • hme0354
        hme0354 kommentierte
        You need a Servo Drive with integrated Position Control.
