Door and Window contacts wireless 3rd party compatibility
  • belisarius
    • 05.02.2024
    • 10
    I would like to add wireless door and window contacts however i cannot use the loxone ones due to the project budget, what are other 3rd party ones that are directly compatible (do not require any 3rd party extensions or software subscripitions etc..).
    Thank you.
  • Iksi
    • 1111
    You could use devices with WiFi or you could use EnOcean devices but therefore you need the Loxone EnOcean Extension...
    • belisarius
      • 05.02.2024
      • 10
      what do you mean use devices with wifi? There are multiple 3rd party door and window sensors that are wireless but how can you connect them to loxone if they are not detectable by air base extension? Do you know of any 3rd party D/W wireless contacts that are directly connected to loxone without any extra extensions?
      • Iksi
        Iksi kommentierte
        Loxone Air is only used by products directly from Loxone. ITS a Loxone technique.
        With WiFi i mean Wireless LAN, thats a difference to Air...
      • 11238
      Shelly Door Window 2 uses Wifi (configuration per device, UDP or http)
      Another option, Enocean sensors and handles are available, requires Enocean Extension.
      If your not ready to do web-based configuration on Shelly‘s, Enocean possibly would be your option.
      • belisarius
        • 05.02.2024
        • 10
        regarding Shelly, how can i configure it to work on loxone miniserver, is there a manual for it that i may access? I assume i would need to add its configuration to the loxone miniserver as virtual inputs/outputs, and thanks for the help.
          • 11238
          There are several Shelly templates from AlexAn in www.loxwiki.eu. I don’t know every detail on these templates but I know Alex is managing them quite well and on time.
            • 4327
            new: Shelly Plus Uni and reed contact​ - Shelly Plus per UDP - LoxWiki - LoxWiki (atlassian.net)
            or​​
            ShellyBLU Door/Window (need a bt gateway: Shelly Plus UNI, Shelly Plus1,....)​
            and UDP with script: Shelly Ble (Bluetooth) - LoxWiki - LoxWiki (atlassian.net)
            • belisarius
              • 05.02.2024
              • 10
              or​​
              does the shelly door window 2 sensor work with loxberry and loxone?
                There are 3 products that I would not install: DW1/2 - very unreliable, 2.5 capacitor problem and the lamps due to capacitors and unstable WiFi settings
            • belisarius
              • 05.02.2024
              • 10
              AlexAn Im just trying to test the shelly sensros connection to loxone, i learned that i need a raspberry pi for it so im using DW2 for testing purpose, later on will most probably use the shelly BLU, current objective is succesfully connecting to loxone.
