dt8 dlx miboxer controller problem
  • Xhorxho Cakalli
    • 12.03.2024
    • 2
    I have bought DALI extension from LOXONE, and for the strips I have bought Miboxer 5050 RGB+CCT led strips from Miboxer, with lighting controllers also of Miboxer, DT8 (type 8) , model DL-X.
    My issue is that when I wire everything, Loxone does recognize the strips, they are active here in loxone config, dimming works, but changing of the lights not. I have made sure to make different lighting controller moods but whatever colour i let in the controller, Loxone cannot change it , just makes the dimming of the current one.​​
  • Patmar90
    • 03.08.2022
    • 1
    I have also tried to get the Miboxer DT8 working but this device has some firmware bugs. The Dali commands which are sent to the Miboxer dimmer are correct but it is not reacting on RGB color commands. There are also some posts in KNX forums where they have problems with this device.
    Zuletzt geändert von Patmar90; 01.04.2024, 08:15.
    • chrisulox
      • 15.07.2022
      • 133
      Is there any other device recommended? I would like to use Lunatone - DALI, but currently they don´t have an RGB-CCT Controller
