Electric Door-Strike for Sliding Door
  • Tico
    • 31.08.2016
    • 1035
    I'm having difficulty sourcing an electric door strike to automate the sliding door pictured below. The left-side of frame is the fixed door-frame. The right-side of frame is the sliding door. I wish to electronically disengage the receiving aperture from the 'claws'. The claws are normally retracted when closing the door, then the door lock swings the claws out to engage. The door frame is already provisioned with 1.5mm 2-core cable for an electromagnetic lock and a CAT6 cable for lock status. The sliding door will be fitted with an electric opener.
Ansichten: 64
Größe: 330,0 KB
Ansichten: 62
Größe: 339,3 KB
    Any suggestions will be gratefully received. I'm also open to modifying two strikes to get the opposing directions the 'keepers' will need to travel.
