Gerade bin ich nun bei Ali auf folgendes Modul gestoßen, was sich aus meiner Sicht sehr vielversprechend liest (ist natürlich nur was für Bastler - das ist natürlich klar). Aber liest sich wie die Eierlegende Wollmilchsau....
1: digital inputs 1-16 can connect some sensors like door sensor/PIR sensor/Gas sensor/Smoker sensor and the self-reset wall switch to control output 1-16.it can trigger the output or sens message to the phone
2:Analog input1-2 is 4-20mA,connect with sensor like Pressure sensor,3-4is 0-5V,connect with sensor like water level detection sensor
3:GPIO’s 1-3 is Temperature and humidity detect sensor port like DHT11/DS18B20,You can connect many pcs DS18B20 to one port,you can read each one on the computer or phone APP
4:RS485(MODBUS) can connect with Power meter
5:315MHz/433MHz RF sender and receiver port:we can use RF wireless signal to control A16 AS wireless switches
6:Ethernet communication:we can implement MQTT communication or LAN communication through Ethernet interface
7:Output connection 1-16:can be 12V or 24V
8:I2C Extension interface:can be connected to DO8 for relay expansion via I2C interface let 16channels become 24 channels
9:Arduino IDE program example code free download on kincony.com website
10:Instructional and using videos on kincony Youtobe channel for watching
11:Support online help and solve question on kincony.com forum website or WHATSAPP
12:If you want work with Tuya,you can buy a tuya license from kincony official store
13:Mosfet controller Power supply can be DC12V or DC24V
Jemand Erfahrung mit so etwas und schon einmal einen Sketch dazu programmiert?
