I’m Andrea, I’m Italian and I’m building my house in east Italy. I’ve tried to find a loxone partner but the nearest is at 3h from my home so my electrician will mount all the cables and the cabinet and I will program loxone.
I’m new in loxone home automation and I’m trying to understand the best solution before buying all the hardware. I’ve read a lot your forum and the official loxone site to understand the best configuration for my house.
This is what I’m thinking to have:
Loxone miniserver
Some extensions (air base, multi air, “extension”)
RGBWW WLAN LED Dimmer with H801 (I think it’s not CE, better DMX ext+ DMX512 Controller?)
Loxone RS485 ext + KMTronic relays for lighting and irrigation
Fingerprint Access Control F6-2 for turning off alarm
Some loxone smart socket air
Some loxone motion sensor Air (only in some rooms in the house)
Motion sensors PIR (like HC SR501) for other rooms
Windows and doors contacts already embedded by carpenter
Pokeys57E for windows and doors contacts and PIR sensors
All the buttons in a “star” solution connected to loxone inputs
Some power sokets controlled by loxone (with 16A relays of the multi air) – alternatives?
Android tablet for all the controls (turn on alarm, RGBW color ecc)
Third party control for heating
Dahua IP intercom (cheaper solution) – I think it will not be implementable in loxone
UPS to guarantee alarm and some controls always working
This is the “base” solution I want to build. After I’m thinking to implement also a QNAP (or something else) for music server, google calendar, loxberry ecc. but I think in the beginning I will only try to focus on the simpler solution.
I want to buy also a power meter but I don’t know which is the best solution in terms of cost/usability. I’m waiting to choose the photovoltaic inverter to understand if I can read some data from it.
I’m trying to read the forum with all your experiences whit google translate but it’s not all understandable… (what’s the meaning of BWM?)
What do you think about my configuration? There is a delay in the UDP communication with Pokeys57E or is a old bug (or I’ve misunderstand)?
